![]() Join Date: Feb 2014
15X10's on my 66 Stepside?
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: 15X10's on my 66 Stepside?
Go ahead and look through my thread.
You'll see several pics from different views. Mine are 15x10 with 3.5" backspacing. http://67-72chevytrucks.com/vboard/s...47#post7337747 . ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Thanks for the reply LostMy65! Truck looks great! I'll check out your thread. What size are your rear tires? How much is your truck lowered? I was thinking of going with 285 60 15's or maybe 295's in Mickey Thompson ET Streets.
#4 | |
Just stumbled across this thread again. Mine all around are: 295/50 15
15x10s on my truck, dont know the back spacing off the top of my head. Love the look.
U.S. Wheel 70 Series White 8-Spoke Wheels. 295/50/15 is the size rubber. |
Thanks for your reply and welcome to the forum!
meowMEOWmeowMEOW
Not a 15x10, but a 15x12. Borderline the most tire you can stuff on a stock rear end. Running 8.5"+ BS tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Thanks for your reply. Truck looks awesome! 15X12's and 325 MT ET streets man that's awesome. Your still running the stock rear right? I was thinking about doing wheel tubs also but I was thinking fleet side wheel wells might work good. They wouldn't be as big as the ones you did though.
#9 | |
meowMEOWmeowMEOW
My truck had a donor for its rear axle and its front suspension. The 12bolt is stock width, but running Moser 35 spline axles and a posi. The truck is tubbed 14", but only 6" or so is needed.
