Old 10-19-2015, 05:15 PM   #1
Kaptain Kadian
Kaptain Kadian's Avatar
180 degrees thermostat
I have a 383 stroker motor with a 3 core aluminum radiator with dual electric fans. I believe I currently have a 195 thermostat and am curious if it would be advisable to switch to a 180. I have read that ideal engine temp is 175 to 180 but OE is 195. I don't do any towing or anything like that. I do have ac as well. Thanks
Kaptain Kadian is offline   Reply With Quote
Old 10-19-2015, 05:32 PM   #2
cdowns
cdowns's Avatar
Re: 180 degrees thermostat
Not worth the effort to change a thermostat
Old 10-19-2015, 05:37 PM   #3
cooperhw
cooperhw's Avatar
I would not worry about it unless you are having overheating issues. As to the radiator, you only have one core, same as every radiator on the planet. It may have 3 rows inside that one core? Not trying to be a jerk, just info.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 10-19-2015, 06:25 PM   #4
hamjet
hamjet's Avatar
Originally Posted by cdowns View Post
not worth the effort to change a thermostat
x2
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-19-2015, 06:44 PM   #5
Kaptain Kadian
Yes, miss typed. Ment 3 row
Old 10-20-2015, 11:09 PM   #6
jt45thomas
It will run better with the hotter thermostat.
jt45thomas is offline   Reply With Quote
Old 10-23-2015, 10:15 PM   #7
Kaptain Kadian
I took it out for a drive tonight and the temperature gauge got pretty hot before it finally started cooling down. The temperature gauge got to over 3/4 of the way and kept climbing until I shut it off. I then let it sit for a couple of minutes and fired it up again. It then started coming back down and sat just under half way after it started cycling the coolant. Could the thermostat just need to be replaced? I just put a new radiator in, and am still tweaking that. I think I got all the air purged, but not sure.
Old 10-24-2015, 08:49 PM   #8
swamp rat
swamp rat's Avatar
Scroll down to the second part of this article and read:
"The Function of the Thermostat & Cooling System Basics"
http://www.tuneruniversity.com/blog/...the-advantage/
The thermostate temp rating only determins the temp that it opens and the coolong system starts operation, the engine overheating is fully a result of the cooling system as a whole and the operating conditions, if its overheating it could be a number of things, a blocked or obstructed system, lack of air flow to the radiator ect..
Is this a new build or one thats been used for some time? anything else new?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-24-2015, 10:59 PM   #9
Kaptain Kadian
It is not a new build, I have had this motor in for a while. The radiator is the only thing new. The temp only spikes up when I first turn it on and it heats up the 1st time. It gets to 3/4 on the temp gauge before the coolant starts cycling and then then it stays cool. It never got past the middle point on the gauge before now before the coolant started cycling. I am hoping I just haven't gotten all the air out of it since replacing the radiator.
Old 10-24-2015, 11:16 PM   #10
swamp rat
swamp rat's Avatar
Ok. Then i would say try a 180 at your leasure being as it raises up untill the thermostat opens then the temp drops. Your coollng system seems to be keeping the engine cooler than the thermostat thats in it. You could pull the old stat and put it in a pan of water and grab a cooking thermometer and find out at what temp its actually openng.. just don't tell the wife. ☺
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-24-2015, 11:27 PM   #11
picklito
I've got a 180 in my 402bbc and that seems to be right around the middle of the gauge range. You may have a t-stat that doesn't really start opening till 195, then cycles well after that. Seen that.
Or... where is your temp sender?
picklito is offline   Reply With Quote
Old 10-25-2015, 12:24 AM   #12
Kaptain Kadian
My sender is in my head by the exhaust. I have to replace the heater core, so I may just replace the thermostat then. Thanks.
Old 10-25-2015, 08:10 AM   #13
hamjet
hamjet's Avatar
your temp. is alot hotter in the head where you have the senser compared to where the temp is at the thermostat. thats why it seems hot. once the thermostat opens it sends fresh water through the heads which cools the sender down. next time leave it running till the thermostat opens, it should drop down. if it bothers you then change to a lower temp thermostat
Thanks, Joe..
Old 10-25-2015, 10:51 AM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
My 402 has a 195 stat with a 3-row radiator, with the temp sender in the LH head. It runs at 30-35% on the gauge. Stock clutch fan. I have not connected a mechanical gauge to see what the actual temp is, but it seems to stay pretty cool. Does anyone know what the rating is on the stock electric gauge, as far as temperature?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-25-2015, 06:31 PM   #15
Kaptain Kadian
I picked up a new 180 thermostat today and when I took the old one out, it was already a 180. Don't know if it is just sticking or what. I drilled a 1/8 hole in it and put the new one in. My old one appeared to already have a hole put in it. I have to replace the heater core next, so this will kind of get pushed to the side until I get that fixed.
Old 10-26-2015, 10:45 PM   #16
mike16
myth
mike16 is offline   Reply With Quote
