Old 10-19-2015, 11:31 PM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
Lowering my pickup
Ok what's the best way to lower a 67 with factory 6 lug drums. I have no desire to switch to drums and no desire for bags or anything extreme I like an old hot rod look and I want functionality too ( obviously can't have the best of both worlds here) but are spindles an option or just springs? Any advice is good advice. Thanks all
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 10-20-2015, 01:05 AM   #2
88Stanger
88Stanger's Avatar
Re: Lowering my pickup
Well i have a 69 swb with stock 4x4 rims (wider is all) on 2.5" drop spindles up front with 1 " drop springs along with 3" drop spring with 1" drop blocks. looks great, not to low but the look is awesome to me. Just my thoughts.
88Stanger is offline   Reply With Quote
Old 10-20-2015, 01:11 AM   #3
BC10
BC10's Avatar
Subscribed!
BC10 is offline   Reply With Quote
Old 10-20-2015, 08:56 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Did you mean no desire to switch to discs?
The best way to lower these trucks is with a 2 or 2.5" drop spindle with a 1 to 2" spring, depending on how low you want to go. This way, you keep the majority of the stock suspension geometry in place, if you do an all spring drop you're going to have the upper control arms shoved full of shims. The back (if coil springs) is easy, but once you get down to 5 and 6 inches you really need to use a shock relocater kit and track bar relocater kit.
I highly recommend ECE. Great stuff. $, yes, but do it once, do it right.
Also, since spindles are the best way to go up front, ECE also sells a 6 lug disc rotor, mine has been on my truck for 10+ years. It's a high quality roter. Since you're swapping spindles... disc brakes are a great upgrade.
I just did my truck recently, I have to find someone to cut out my upper shock mounts for me (blazer tank in the way, I'd rather pay someone $20-30 than drop everything out).
Check my "1967 CST Shop Truck Rebuild" thread below!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-20-2015, 10:29 AM   #5
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Easiest and least expensive way is drop springs at both ends.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 10-20-2015, 01:39 PM   #6
northerngmc
northerngmc's Avatar
I just dropped my 68 C20 using drop springs. I am not sure if you will find drop spindles that will work with drum brakes.
I just used a basic kit of springs and shocks to complete a 2" front and 4" rear drop.
One word of caution. Most of the information I read here stated the easiest way to change the front springs was to pop the lower ball joint free. On my 68 C20 with drum brakes the lower control arm would not clear the backing plate for the brake drums. I ended up unbolting the ubolts that hold the lower control arm on at the frame end. Went well. That and you will find many threads on here of people trying to get the lower ball joint to pop. Mine took banging and heat to only find out that the lower control arm would not drop because it was hung up on the brake backing plate.
I am very happy with my 2/4 drop.
And AFTER
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-20-2015, 01:59 PM   #7
Lou Boffa
Lou Boffa's Avatar
subbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 10-20-2015, 11:40 PM   #8
CST10
CST10's Avatar
Here's a 3/5 spring only drop with drums all the way around. I put a 1" taller rear tire to give it an ol school rubber rake.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 10-21-2015, 07:12 AM   #9
Robznob11
Robznob11's Avatar
How good a fabricator are you, 3" body drop is the cheapest but takes some work.lol. I would go with spindles and spring s , they used to have them for drums not sure now. Or go with both like I did.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-22-2015, 08:42 AM   #10
68Stepbed
68Stepbed's Avatar
I'm not going to tell you what to do here, but, switching to front disc brakes is by far the best upgrade you can make especially for the sake of safety. As Jesse mentioned above, ECE sells a high quality 6 lug disc conversion with either stock height or drop spindles.
I'll also recommend [url=www.earlyclassic.com]ECE[url] over any other brand. Great quality components and great customer service. They also have "stance" photos on their website of different drops so you can decide what you like.
As for keeping it driveable, you can go as low as a 4/6 and still maintain a quality ride that doesn't require special modifications to install or maintain.
Good luck with making your decision and be sure to post lots of photos when you're done.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-25-2015, 06:42 PM   #11
67chevy_hotrod
I would like to not switch to disc I meant because I want to run factory 6 lug 15 inch steel wheels.. Does anyone know if anyone sells drop spindles for drum brakes?
1967 Chevy CST 10
1969 K10 Suburban
Old 10-25-2015, 08:10 PM   #12
rattle69
rattle69's Avatar
I'm sure I've seen drop spindles for 6 lug drum before. Can't remember where. On another note, if you want to stay with 6 lug their are 6 lug disc brake kits available too. I think they come as a kit with drop spindles too. Check the vender marketplace. I'm sure somebody else will chime in with a link. Good luck from down the road in Puyallup.
70 lwb c-10
rattle69 is offline   Reply With Quote
Old 10-29-2015, 11:30 AM   #13
68Stepbed
68Stepbed's Avatar
As far as I know, no one makes a drop spindle for the drum setup. What about finding a set of 6 lug wheels from the later model 4x4 trucks?
Matt
Old 10-29-2015, 12:41 PM   #14
BC10
BC10's Avatar
What year models.
Old 10-29-2015, 03:04 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Got a torch?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-29-2015, 06:23 PM   #16
jacmac926
I did a 2/3 spring only drop on my 67 with disc in the front no clearance issues and I'm using rally wheels off a 86 k10.
Mike
67 c10 stepson lwb
08 silverado 4x4 dd
jacmac926 is offline   Reply With Quote
Old 10-29-2015, 06:41 PM   #17
michael bustamante
michael bustamante's Avatar
if you were to go 6 lug disc conversion, the wheels you need would come off 73 and newer 4x4 trucks. look for 4 nubs on the wheel.
or the rallys. those fit nice on the drums
if you keep the drums though dont drop the front end too much with just drop springs or cut springs, you'll never get the alignment right.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-30-2015, 12:51 AM   #18
OregonNed
OregonNed's Avatar
That drop looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-30-2015, 05:38 PM   #19
68Stepbed
68Stepbed's Avatar
Originally Posted by BC10 View Post
What year models.
71 up 4x4s. Mainly the 73-78ish. Most of those came with 15x6.5 or 7(some even had 15x8) steel wheels and dog dish caps. They're almost just like the original 67-70 steel wheels, but with a slightly different center to clear the disc brakes.
There's also the 4x4 rally wheels, but I'm picking up the vibe you want to stay with the classic styling.
Matt
