Old 10-20-2015, 12:57 AM   #1
Chevy1966
Transmission Modulator
Does anyone have the technical details as to the difference in the stripe colors on the transmission modulators? I've searched, but couldn't find an answer. I understand how to adjust them, but how is a blue stripe different from a green or red? How would I know what flavor came from the factory? I'm replacing one on my '76 C25 TH350. Thanks in advance! --Rob
66 Custom Camper 327 AC PS PB
66 C20 292
76 C25 Sierra Classic
76 C25 Sierra Grande
76 Camper Special
77 Sierra Grande
02 Suburban - the DD
Chevy1966 is offline   Reply With Quote
Old 10-22-2015, 07:13 AM   #2
Desert1957
Desert1957's Avatar
Re: Transmission Modulator
The green stripe is the most common, colors mean different spring tension, the softer the spring the lower & softer the shift points . By adjusting the screw out you allowing the vacuum to act more on the modulator . I use to order all green stripe for use in the 400 and 350 . Try not to adjust it too much, a few turns is usually enough.
Desert1957 is offline   Reply With Quote
Old 10-22-2015, 07:22 AM   #3
Chevy1966
Thanks for the info - makes sense! --Rob
66 C20 292
76 Camper Special
77 Sierra Grande
