Old 10-20-2015, 09:33 AM   #1
morethanstock66
morethanstock66's Avatar
Shorter Aftermarket Column?
My '66 was an old column shift, as many were, and since has been converted to floor shift. The column needs to be replaced, as it is binding, and slowly coming apart, but I was looking to go shorter.
Name:  COLUMN PROFILE.jpg
From what I understand, the OE column is about 32" long. I was curious if anyone has had a bench seat, with the cab gas tank, and put in a shorter "universal steering column." I feel as if the column has extra room to spare..
Name:  TAPE MEASURE PIC.jpg
I am looking to get a little more elbow/lap room Any advice, or thoughts would be appreciated, thanks.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 10-20-2015, 10:47 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Shorter Aftermarket Column?
I shorten a stock column for a buddy. I took 3 1/2" out which moves the wheel forward BUT is also moves it down. Since he was putting a 15" steering wheel, it wasn't too much of a problem with leg to wheel space but if you are going to use the stock wheel, it could get really tight. If you get a tilt column, it might not be that big of an issue but figured I would point it out.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-20-2015, 11:01 AM   #3
morethanstock66
Ooh.. good point. I totally overlooked that aspect of it. I like the OE style wheel and cap, but that would be inconvenient. I was also looking at aftermarket columns, like Ididit, and they say you cannot use OE style wheels with them, perhaps that is why. I have no problem converting to an aftermarket/smaller wheel, but with a manual box, it would be a bit more of a workout
