10-20-2015, 05:52 PM | #1 |
Alien object in intake port
The 250 in my 68 K10 always had a random misfire at lower rpm's. It would come and go...
Today I'm preparing to pull the engine for a 292 replacement so I remove the intake and found this inside...The hammered closed end was towards the valve and the port floor was clean from the tube knocking around.... |
10-21-2015, 01:05 PM | #2 |
Re: Alien object in intake port
Would that be part of a valve stem?
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
10-21-2015, 03:58 PM | #3 |
I had a similar situation with my '65 Belair and its 230. I had changed the head and intake together(long story) anyway about 6 months latter when I removed the intake to install new gaskets I found one of the carb nuts sitting beside the no. 4 intake valve. Surprisingly no damage or problems were caused by it.
10-21-2015, 06:44 PM | #4 |
"Why, that's a nick knack Patty Black. Give the frog a loan".
Serious though, it kinda looks like it could have started life as a tube under the air filter that got dislodged and your motor ate it.
"Life is too short to drive a boring vehicle". Later, Wayne |
10-21-2015, 08:21 PM | #5 |
That is an anti-carbonator. Keeps deposits from forming on the back of the intake valve.
10-21-2015, 08:23 PM | #6 |
Kinda looks like a piece of metal fuel line.
10-22-2015, 06:22 AM | #7 |
I was told it's the PVC extension pipe....A short length of tubing that extends into the intake manifold and curves away from the 3-4 intake port...Supposedly the PCV could cause the enter cylinders to run lean...
10-22-2015, 09:34 AM | #8 |
2 summers ago I had to replace the intake gaskets on my 98 gmc. got the manifold off and there was a stick about the same size and length just laying in the lifter valley! I am the second owner of the truck and was friends with the previous owner. he never had the manifold off. must have came from the factory in there!
Brian |
10-22-2015, 04:13 PM | #9 |
I agree. There is a short tube like that inside the center intake port. It draws vacuum from under the carb instead of from the 3-4 intake runner. It would cause a rough idle without it.
