Old 10-20-2015, 08:40 PM   #1
Hampshire
Hampshire's Avatar
Good deal on a 350 crate
Once a year they knock the price down on these. If you don't need lot of HP, it can work for you. Reg gas, reliable, etc.,
http://www.ebay.com/itm/Chevrolet-Pe...3D181894461720
Hampshire is offline   Reply With Quote
Old 10-20-2015, 10:16 PM   #2
mobileortho
mobileortho's Avatar
Re: Good deal on a 350 crate
I bought one last year from Jegs. It is a good engine but I wish it had a bit more power. Thinking about going with the Chevrolet Performance 19210007 350ci/330HP HO.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-20-2015, 10:25 PM   #3
flashed
I put one in my 72 shortbed and it has plenty of power .I put a 290 HP one in my wife's 72 Malibu convertible and it is quite peppy.
flashed is offline   Reply With Quote
Old 10-20-2015, 10:57 PM   #4
Hampshire
Hampshire's Avatar
350/330 was a real strong contender, but I wanted that kind of HP with the Gen1 heads. We changed to a roller cam/lifters/rockers with a slightly hotter profile than in the crate 350/330. While the heads were off went for some porting & a bit of a compression bump. Probably cost just marginally less or the same as the 350/330 - I paid $1259 last year to JEGS, so that helped with overall cost.
Got many of the ideas from some on-line magazine article where they built up a basic crate in steps. My idea was to get at least 300-325 hp. It's strong & pulled nicely from day one (Labor day) ...1500 miles later it's starting to settle in & feeling better every day...
Old 10-21-2015, 03:38 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
With this particular engine its does not have the holes needed for a GM serpentine belt drive system. there is no upper hole in the right head near the intake. If your using V belts then it a great motor for the price
dwcsr is offline   Reply With Quote
Old 10-21-2015, 12:13 PM   #6
mobileortho
Yeah, found that out the hard way. Attempted to drill & tap the missing hole as I've done previously & ended up in the water jacket.
Robert C.
1950 3600
Old 10-21-2015, 01:04 PM   #7
mobileortho
So, you're saying that you got 300hp with just those changes? I'd contacted Jegs a few months ago about possible upgrades to get about that type of hp & was told that a cam & heads would only get me so far without touching the internals (maybe about a 30 hp bump), hence my decision to just go with a different motor. I really should have read the listing more closely before I bought it. It thought it read 260 base hp but it was actually only 195 and "capable" of up to 260. I'm using TPI with the Edelbrock high flow intake & runners. I figured that would give me a little bit more power than the carb.
Robert C.
1950 3600
Old 10-21-2015, 03:58 PM   #8
Cuttin up
Cuttin up's Avatar
The dished pistons are the set back to the 195 horse engine. The heads are large cc which gives you tiny compression. You could get to that 300 mark, but you would have to change the heads, cam, and pistons as well as have a good flowing intake to top it off. I've played with the 260 horse engine in a couple different cars and with just a heads/cam change they picked up a lot.
Cuttin up is offline   Reply With Quote
Old 10-21-2015, 04:41 PM   #9
1-ton of fun
polishing a turd
1-ton of fun's Avatar
that just doesn't seem like that good of a deal, unless you want a lo-po motor.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 10-21-2015, 10:57 PM   #10
Hampshire
Hampshire's Avatar
Yes. Could be more, but I like to keep numbers on the conservative side (see links below). It's just not parts, it's having a talented machinist next door to massage the heads + a talented builder who specializes in vintage race cars.
We basically followed the model in these two links below:
http://www.superchevy.com/how-to/463...-engine-build/
http://www.superchevy.com/how-to/463...gine-build-ii/
...note they made it to 336hp. We used the same cam kit/rocker arms. Our machine shop is good, and I think we got significant gains from porting & a compression bump, but maybe not as much as they did.
..if higher numbers do it for you, fine. I like it and the builders in our area like it, too. They've tested it & love the grunt, drivability & reliability. Sure, there is tons of peer pressure out there on the circuit to say you have more than 400hp or whatever, but I think a good ride is more then that...
Old 10-22-2015, 05:38 AM   #11
mobileortho
For me it would probably be easier and more cost affective to just sell mine & buy the other one.
Robert C.
1950 3600
Old 10-22-2015, 12:33 PM   #12
1-ton of fun
polishing a turd
fast trucks do it for me, not high numbers...
Old 10-22-2015, 12:48 PM   #13
Hblee
Hblee's Avatar
Sounds like a better deal than this one...
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida that she's cherry.
Hblee is offline   Reply With Quote
Old 10-22-2015, 02:22 PM   #14
mr48chev
mr48chev's Avatar
I'd check with the local GM performance dealer's parts counter for the price they will sell it for. Or any other GM performance crate motor. There are some around that will give a pretty decent discount.
My ongoing truck projects:
Old 12-22-2015, 11:50 PM   #15
mobileortho
So I've been doing my homework on the head/cam swap. This link in Hot Rod mag has me thinking about giving this a try.
http://www.hotrod.com/how-to/engine/...head-shootout/
I came across a set of the Patriot aluminum heads mentioned in the write up for $500. Although they scored very well in the article I'm finding mixed reviews other places. Anybody using them? I've been on the phone with the Jegs techs and with a Comp cam, heads and the hi- flo Edelbrock tpi setup I'm using they say I can have a major increase in hp.
Robert C.
1950 3600
