dana 60 REAR axle
Hello all,
Can anyone confirm what year GM stopped using the dana 60 and switched to the semi float? Was it only in 3500 or did 2500s have the 60 also? I am hunting for a Chevy dana 60 for the rear of my suburban. I am not interested in the 14 FF. (to big) Thanks in advance. |
Re: dana 60 REAR axle
Probably not very helpful, but it is all I have. Once had a 84 van with the 9.5 sf axle in rear. My dually 86, is Dana 70 out back. Military trucks sometimes had unusual running gear, but I don't know much about what came when.
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
#3 | |
My driveline shop recommends keeping and rebuilding the Semifloat. It will only be for mild wheeling and towing. Any feedback on just keeping the OEM? |
I've seen them in 73-75 k20 suburbans but that Iis the only ones I've seen yet to see one in a truck and what's wrong with your current semi floater if you were able to brake it bad enough you need to replace it the full floater wouldn't be a bad idea lots of aftermarket support and easier to find. But that just my opinion. I plan on a shaved 14bolt ff in my k5 even though I'm only going to run 35s I am going to be putting down some good torque with my new motor and I have a heavy foot
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 Last edited by bmchevy1979; 10-22-2015 at 12:46 AM. |
Yeah last gm rear dana 60 i seen was in the early 70s,What size tires you want to run or have now?
I don't think that I have ever seen one with a dana 60
#7 | |
my shop says the sf is more than adequate, i just hate pumping $ into the sf axle. more mental on my part. |
I would sell the ford 60 and use the money to fix the axle you have now or go full float 14 bolt.
If you want to stick with dana you might be easier to find a dana 70
I know GM used the 60's to 72. Can't verify any further. 73 they started with the 14 bolts. I prefer the FF rears as the axle bearings ride on the housing not the axle.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
72 was the last year of the dana 60 in Chevy trucks as they went to the 14 bolt. I would go with a ff if you are towing or hauling.
#12 | |
I am going to mock it up over the next week,, So my list is this, add to it if you have input; the easy;; cut and weld perches. cut and weld shock mount. the unknown drill the drums for the larger wheel stud (ford=1/2 chevy =9/16). or use ford lug nuts for a while.. E brake cable mod??? |
