new
Picked up a 1952 chevy 3100
olds 350 with th400 Pretty original Great shape Keeping it on the road is a challenge. Tried adjusting the steering box. Any other ideas? Mustang II? I've only seen sbc mounts for them. Help |
![]() Join Date: Sep 2015
Re: new
Welcome! From Sioux Falls South Dakota
I went with a 1973 Nova subframe Not sure about the mounts but ANYTHING can be fabricated I'm sure you can figure something out on a thread here |
#3 | |
Re: new
collectively they all add up to play in the steering once you go to mustII then everything changes brakes, column and half the under dash wiring need to be modified and then your stuck with 5 lug lowered front and 6 lug stock height in back pretty soon your truck in in 1000 pieces all over the garage ![]() as for motor mounts, you can fab any motor mount for any motor they're actually one of the easiest fab projects
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: new
Also I'm having gas pedal issues
I'm not getting enough leverage to get my secondaries to open I have an original gas pedal put no linkage. Anyone have a diagram on how it works I put an aftermarket one in but not enough leverage |
![]() Join Date: Jun 2015
Re: new
Welcome from San Diego, post 2 pictures of your linkage one linkage static and 1 with pedal fully depressed.
It's not Rat Rod, it's an unfinished project |
Re: new
At the carb
Re: new
Firewall
It's alsways something.....
![]() Join Date: Nov 2008
Re: new
I think I would approach this in a specific order:
1. Get it where I could keep it in the road 2. Get the secondaries to open
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Re: new
ive got stock pedal with aftermarket linkage on a 327 4 bbl. I will post info on the vendor when I get home.
