Old 10-21-2015, 11:51 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Front "A" arm shafts/bushing replacement
Front control "A" arm bushing replacement..is it correct?
I replaced all the shafts on the control arms. I tightneed both sides evenly and until the big nut is flush against the control arm but I still have a gap (even on both sides) between the bushing and the a arm. I have attached a picture. Thank you. (TX firefighter/lowlife)??!
John
1999 Toyota Tacoma 4x4
Old 10-22-2015, 10:58 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Front "A" arm shafts/bushing replacement
I don't have any close up pics but it seems your outer bushing/nut is not seated all the way in the pic. Here are two different sets of arms I did and you can see there is no gap between the nut and arm.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-22-2015, 01:11 PM   #3
oldblue1968chevy
Thanks Chevymike.
I got the big nut torqued all the way down after the picture. I'm just wondering about the rubber seal should it be up snug against the arm? Thanks!
John
Old 10-22-2015, 02:46 PM   #4
chevy_mike
chevy_mike's Avatar
Not really needed. The part that seals out dirt is the area on the shaft (the area that the seal necks down to). You should be fine.
Old 10-22-2015, 10:03 PM   #5
oldblue1968chevy
So I just discovered that my (powdercoated) mcgaughys drop spindles don't have the holes for the dust covers
Do I drill into them and tap them? Or run without dust covers?
John
Old 10-23-2015, 03:07 PM   #6
69gmcc10
69gmcc10's Avatar
I don't mean to hijack this thread, but it seems like a good time ask this question.
What is the torque spec on that big 1 5/8" nut? I have heard numbers as high as 280 ft.lb. and as lo as 115 ft.lb.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-25-2015, 12:00 AM   #7
oldblue1968chevy
I believe my Haynes book was like 200+ ft lbs..I'd have to look again to be sure..
John
Old 10-25-2015, 12:34 PM   #8
chevy_mike
chevy_mike's Avatar
Dropped spindles typically are design not to work with dust shields. I have always run without them.
Old 10-26-2015, 01:35 PM   #9
69gmcc10
69gmcc10's Avatar
Thanks, the only thing my book says is take it to the dealership...
I think they would work if you drill and tapped the bosses on the spindle, but most people don't run them. They would probably be a good idea if you are on dirt roads allot, I can certainly see that they protect from rocks getting stuck in the pad.
