10-22-2015, 09:39 AM | #1 |
Dually conversion questions
I've got a 71 3/4 ton frame with 88 dually front and rear suspension. I'm putting a 48 FORD (grandpa's old rice truck on it) & it will need a narrower track to get the 22" semi wheels inside the fenders. Can I use a 3/4 ton rotor on the one ton spindle? If I need a 3/4 ton spindle will I need to change ball joints to 3/4 ton as well? Also, does anyone know if the dually rear end is same width or different from the 3/4 ton single wheel (it'd be great if it or another rear end was about 3-4" narrower for my particular build
Thanks for any imput or info you may share with me Wade |
10-22-2015, 10:04 AM | #2 |
Re: Dually conversion questions
Pbfab can make a set of a arms that are shorter for it,The rear axle the single rear wheel and pickup dually are both 67 inches,But if you use a cab and chassis axle those are 63 inches wide.
10-22-2015, 10:20 AM | #3 |
Yes, the Porterbuilt may be a necessity but on this one I was hoping to do it with stock parts. Thanks for the rear end info as well
Wade |
10-22-2015, 11:28 AM | #4 | |
67-72 parts collector,…
Then you would use the 3/4-ton or 1-ton (single wheel) rotors. I'm sure thats what Michigan Metal Works uses also, with their flat plate a-arms. Since your swapping bodies,... you might want to measure how long the lower a-arms would need to be. It may be less than 2" or the stock a-arms might be fine also. But I would start with single wheel rotors, and not the dually rotors.
10-22-2015, 11:45 AM | #5 |
Thanks Keith, I was told by switch suspension that the 3/4 and one tone shared the same drop spindle. I know you have a wife knowledge of GM trucks, is that what you understand to be true as well? Are the brake calipers the same too?
Thanks again, Wade |
10-22-2015, 11:50 AM | #6 |
I was thinking the single wheel 1-ton rotors had a different style caliper mount.
I'm pretty sure the balljoints and tie rods are the same between 3/4 ton and 1 ton. I'm sure the dropped spindles for 73-87 (and the square body 88-91) are available. Just might require a search to see if there is two different part numbers between 3/4 ton and 1 ton trucks.
10-22-2015, 11:56 AM | #7 |
10-22-2015, 01:28 PM | #8 |
Thanks Keith. I'm going to mock the truck all the way up with body on the chassis as is and see how much I need to pull the wheels in before I buy anything. Thanks again
Wade |
10-23-2015, 02:04 AM | #9 |
He does make a good point get the body on the frame before you start changing things out so you know for sure what needs to move.
