![]() ![]() Just picked up the truck going to replace spark plugs , do an oil change and start to clean up the interior . |
Re: 86 short bed
looks very good!!!
plans? |
Re: 86 short bed
Thank's , i plan on 2 1/2 drop spindles on the front and im guessing 6 in rear . Will see how it goes i have to get it tagged 1st . I'm going to drive it as is for a while i have to save up some money.
Diggin The SquareLife
Re: 86 short bed
I also would do springs in the front
Re: 86 short bed
I was thinking about that , i just don't know if i should get stock springs or shorter springs.
Re: 86 short bed
u can get after market drop springs or get new stock big block springs an cut a coil of of them....just depends on what u wana do
Re: 86 short bed
I have sum pictures but I can't load them from my phone. I'll try again tomorrow.
Re: 86 short bed
Added a new steering wheel still need to clean the interior . Also need to paint the engine bay . I think for now ill be driving it as is i have to save up some money.
Re: 86 short bed
Hey guy's previous owner installed these im thinking of removing them . Do i really need a tach ? And will the stock oil gauge be sufficient ?
Re: 86 short bed
Hey guys looks like i got lucky and found a working radio this weekend. Anyone know where i can maybe get the missing buttons ?
Re: 86 short bed
Try lmc truck
Re: 86 short bed
Love the truck ! Where did you find that radio ? Looking for a stock oil pressure gage myself. Right now I am changing the timing cover, and oil pan gasket.
84 step side 87 swb |
#13 |
Re: 86 short bed
Thanks , I found the radio at pick n pull in Dallas . I'm looking for a stock temp gauge also another cluster the previous owner hacked up the cluster.
#14 |
Re: 86 short bed
Hey guy's im wondering if anyone knows what this came out of ? Or will it work on my 86 ?
#15 |
Well i found a cluster and took it apart cleaned it out painted the inside . Next im going to paint the needles . Im going to add LED lights hopefully it wont be too bright .
#16 |
Re: 86 short bed
My buddy Felix sprayed the needles for me im happy the way they turned out.
#17 |
Re: 86 short bed
Weather permitting ill be removing this mess and installing my new cluster.
#18 |
Re: 86 short bed
Well i installed the new cluster , but i didn't like how bright my gauges came out. I think i will use brighter LED's . Now i need to wait for the bulbs to come in .
#19 |
Re: 86 short bed
#20 |
Re: 86 short bed
I also added new dash speakers and added sum maroon trim and sun visor
#21 |
Re: 86 short bed
Hey guy's just wanting sum feed back what do you think about this set up. Leaving the door panel black and the pocket burgundy and also the padded area burgundy also.
#22 |
Re: 86 short bed
I'm not feelin it. I like the idea of contrast.... I just think that might be too much.
#23 |
Re: 86 short bed
What do you think will look better ?
#24 |
Re: 86 short bed
I would dye/paint the door panels burgandy since that appears to be the color choice your going with for the interior (?).
#25 |
Re: 86 short bed
Yeah burgundy is my choice in color. Okay cool thanks for the input.
