![]() Join Date: Apr 2007
Tach Cluster
GM Tach dash - seems to be in good over all condition. The Bezel was rough so I have a new 69-72 that goes with it. Slight scratch on lens (see pic) $275 shipped the the lower 48.
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Tach Cluster
If tach is OEM and for 8 cyl motor and works I'll take it...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Tach Cluster
Carpe manana
Re: Tach Cluster
Sounds like cluster wasn't removed by yourself from SPID listed tach truck - one way to be sure. Can you post pic of the rear of the tach without the printed circuit in the way? Does tach work?
![]() Join Date: Apr 2012
Re: Tach Cluster
If I had to guess, I would say it is aftermarket. Here is a picture of one of the oem ones I have.
![]() Join Date: May 2010
Re: Tach Cluster
Every reproduction tach I've seen has the screws on the front in different locations than the originals. The reproduction's screws are higher and spaced farther apart than the originals. More like those on the speedometer. Here's a picture of my GM tach.
Re: Tach Cluster
Here's the close ups
Re: Tach Cluster
Another
Re: Tach Cluster
One more
Carpe manana
Re: Tach Cluster
Thanks - I appreciate the extra pics. Looks like aftermarket tach so will pass. Best, Pete
Re: Tach Cluster
ttt
