09-14-2003, 07:08 PM | #1 |
what kind of carb is this?
Hey does anyone know what kind of carb this is, Other than it being a 4 barrel i dont know anything about it. Any info would be great. Thanks guys.
09-14-2003, 07:08 PM | #2 |
left side
09-14-2003, 07:09 PM | #3 |
right side
09-14-2003, 07:10 PM | #4 |
its all about the +6 inches
That is genaricly called an AFB. It could be a Carter, a Webber, or an Eldebrock carb.
09-14-2003, 07:13 PM | #5 |
what does AFB mean?
09-14-2003, 07:16 PM | #6 |
Formerly yellow72custom
Allumium Four Barrell
Edelbrock versions are zinc BTW, but the Carters are made out of allumium. Great carb IMO.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
09-14-2003, 07:25 PM | #7 |
huh?
I agree, they seem to be excellent carbs. My 406 has one, and I love it, HUGE improvement over the Holley that I was running. Easy to tune, and tough as nails as well.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
09-14-2003, 08:48 PM | #8 |
holley is a ****ty carb...that looks like a carter to me...i ditched the ol holley i had and am currently using a demon on my 396
09-14-2003, 11:43 PM | #9 | |
Bloo
personally, ive had 3 quadrajets, one edelbrock, and a holley.... i wouldnt trade the holley for anything. 2 of the quads were so so, the e-brcok wouldnt do crap, one quadrajet ran good, but none of them will set you back in the seat like the holley will. i changed absolutly nothing but the carb
oh, and i agree with the carter AFB as to whatyours is
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
09-14-2003, 11:50 PM | #10 |
It looks exactly like the Carter 9000 series AFB carburetor I just rebuilt. The vacuum ports are even the same (which is the only difference between the one pictured and the Edelbrock 1400 series carburetors).
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
09-14-2003, 11:55 PM | #11 |
Here is a comparison to the Edelbrock. This one is a 750 with electric choke.
Looks EXACTLY the same except the color and the name rivited on the front. |
09-14-2003, 11:58 PM | #12 |
I have even used a carter top half on top of an Eldebrock bottom when i was in a pinch one time. You woulda never known, ran like a bat outa h*ll.
The AFB is a very good design with few flaws. The holley is a fairly simple carb that makes great power, but is so flawed that many ppl refuse to ever use one again. The Quadra Jet is a great carb that is so complicated, ppl will use them untill they start messing up, and then bail on it and look for a replacement rather than try to rebuild it. |
09-15-2003, 01:42 AM | #13 | |
senior member
69 GMC bagged |
09-15-2003, 01:42 AM | #14 |
thanks alot guys
09-15-2003, 02:11 AM | #15 | |
Low & Slow
70' C-10 LWB Fleetside 4.5/6 drop |
09-15-2003, 07:37 PM | #16 |
if you guys want real performance from a carb...check into demon carbs....the rest are just scrap in comparison
09-15-2003, 07:38 PM | #17 |
senior member
not all of us have 1500 to spend ona carb
69 GMC bagged |
09-15-2003, 07:42 PM | #18 |
Road demons go for less than $300 IIRC....
09-15-2003, 07:48 PM | #19 |
I'm a die-hard Holley guy, never had any problems other than a blow power valve or two. I had bad luck with a Carter, it's just the luck of the draw.
