427 Crew cab mpg question
What do you guys usually get for 427/454s in your crew cabs?
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: 427 Crew cab mpg question
87 cc dually,454/TH400 RWD running stock size 215/85R16 and 4:10 rear end gears on the highway I was lucky to get 7-8 mpg.
Swapped out the rear end gears for a set of DANA/SPICER 3:54's as well as a GEARVENDORS OVERDRIVE UNIT which when engaged gives me the equivalent of a 2:77 rear end. Highway mileage is now 15-17 mpg depending on how much lead has filled my go-pedal foot.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
8-9mpg's on the factory motor in my 89 (454/th400/4.10's/no OD/235-85-16's).
It's rebuilt now but haven't done highway miles to see if things are better now that it's fresh.
Even the newer FI engines get bad mileage. My 99 with overdrive and 3.73 never gets better than 12. Its usually 9-11. But it stays at 9-11 when I tow.
If you buy a big block truck, you're not buying it for fuel mileage. I tell myself that every time I put gas in it. |
I think it is easier with the monster to measure in terms of gallon per mile,which is about 0.2 gpm
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
