10-23-2015, 01:50 PM | #1 |
NOS Sport Mirror Screw sets
Seven sets of sport mirror screws for sale. Paypal preferred. Four sets may already be called for by the following, PMs sent:
1rippen6 my71gmc cst204x4 randy.powell Six sets of six screws are $29 each with shipping. All Sold One set of six screws is $20 with shipping. I singled these out, because either they weren't quite as bright or the edge around the bottom of the heads weren't quite as narrow. These are pictured in the box, 3rd image. Probably sold. Note: Appears to me that you need to ream out your NOS reinforcement bracket (or even repro.) some to get these to bite. I tried them on my NOS reinforcement bracket and it wouldn't take. That said they fit perfectly into the mirror, and any smaller would be incorrect. That and the part number is correct. If anyone knows better, then please chime in. Other than the four posters mentioned, first in line get them.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-31-2015 at 08:23 PM. |
10-23-2015, 02:24 PM | #2 | |
Carpe manana
Re: NOS Sport Mirror Screw sets
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-23-2015, 02:31 PM | #3 |
I will let you know tonight if that is ok thanks
10-23-2015, 02:36 PM | #4 | |
These are the same as what I've got: http://www.ebay.com/itm/NOS-66-67-68...-/191123029685 Here's the parts wiki: http://www.gmpartswiki.com/getpage?pageid=22762
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-23-2015 at 02:42 PM. |
10-23-2015, 02:38 PM | #5 |
Carpe manana
I looked but there is no # on the paper envelope the screws came in.
10-23-2015, 02:41 PM | #6 |
If available, I'm in for a $29 set.
Thanks, Lee
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
10-23-2015, 02:50 PM | #7 |
If you look online for repro., you'll find both types.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-23-2015, 05:02 PM | #8 |
Works for me. I can see where the self-tapping are the easier route. I've now seen two kits that have them.
Me, I'm going to use these, and carefully ream out the reinforcements. The bottoms are tapered. They're real pretty, and from what I see on the web are correct. Incidentally, these are grade 8.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-23-2015 at 05:54 PM. |
10-23-2015, 05:22 PM | #9 |
I will take a set of six pm me payment info thanks
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
10-23-2015, 06:38 PM | #10 |
I am good with taking 6. I am fairly certain my back plates have something like a nut on them, and these will work great. The NOS plates don't look like what I have in my Jimmy, and I assume mine are original?? Either way, I will take them.
10-23-2015, 06:51 PM | #11 |
Paypal sent for $29.00. Thanks. Keith
10-23-2015, 08:14 PM | #12 |
Packed and ready to go, thank you. Curious what your plates look like. Nothing comes up in the parts book for GMC at the moment for the screws, reinforcements or gaskets. Can't imagine the sport mirror set up for GMC differs from Chevy.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-23-2015 at 08:26 PM. |
10-23-2015, 08:42 PM | #13 |
I took this picture off of the forum, but I think it looks like this.
10-23-2015, 10:11 PM | #14 |
I would like to check my plates in the morning to see if they have the nuts or not.
10-23-2015, 10:18 PM | #15 |
Well look at that. Those come off the same truck? I'll take a stab at this. The top one is an original reinforcement, the bottom is a later version. I've got about 10 possible scenarios in my head right now. Another mystery.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-23-2015 at 10:31 PM. |
10-23-2015, 10:21 PM | #16 |
LOL I had plates both ways also but sold most I just need to see which ones I kept.
10-24-2015, 07:25 AM | #17 |
I'll take a set if you have any left
10-24-2015, 01:56 PM | #18 |
I checked my plates and they have the nuts so I will take a set plus the other six that are not as bright if still available can you combine shipping? Thanks
10-24-2015, 08:40 PM | #19 |
Carpe manana
Good info here - some plates had nutserts, some did not.
10-25-2015, 06:45 PM | #20 |
Here are the plates I have
10-26-2015, 06:16 AM | #21 |
Are you selling these or using them?? A friend of mine needs a passenger door side one with the nuts. Thanks.
10-28-2015, 08:39 PM | #22 |
Here they are with the nuts weld on let me know if interested
10-29-2015, 05:53 AM | #23 |
Nice idea to weld the nuts on.. I will check and see if he is interested. Do you have a price for one, and both?
10-29-2015, 06:09 AM | #24 |
I will take a set and i need a set or backing plates if anyone has a extra pm address I send cash
10-29-2015, 07:39 AM | #25 |
