Old 10-23-2015, 02:22 PM   #1
daveklein
Steering Box
Hey guys...I have a 67 with manual steering and want to fill the steering box..I know where to put the grease in but where does air escape when putting lube in ?? It fills thru one of the bolt hoes so not much room for venting... Dave
daveklein is offline   Reply With Quote
Old 10-24-2015, 10:33 PM   #2
mike16
Re: Steering Box
you only put grease in during the rebuild process. after that you top it off with 90 wt ,
if it leaks I cheat a little and use STP oil treatment in. its thick enough that even on older trucks with the box next to the manifolds it does not thin out enough to leak out
mike16 is offline   Reply With Quote
Old 10-27-2015, 10:19 AM   #3
daveklein
Re: Steering Box
Hey Mike...Thanks for the info...But I still don't know how you get the STP in the little bitty hole with no vent.?????? Dave
