Brake adapter cracked
I need help. I have a 1970 K20 with an open knuckle front differential and drum brakes. Where the flex hose screws into the left front wheel cylinder there is a 45 degree angle brass fitting that the brake hose connects to, which in turn connects to the wheel cylinder via a banjo bolt. Mine is cracked an I can't find one. Does any one have one for sale?
Re: Brake adapter cracked
You have to get a replacement brake hose that will have a banjo fitting on it and should have an angle bent into it, if your doing one hose you should think about doing all of them including the single hose in the back, they are not made to last forever.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Feb 2014
I may have the fitting. Can you post a pic of yours? Bruce
Posted via Mobile Device |
That would be great. I'm new at this so I'm not really sure how to attach a picture, so please bear with me.
I'm fairly new also. I understand. Bruce
I take it the pictures didn't attach.
Try again
Sorry, I do not have that fitting. Bruce
I appreciate the effort. Thanks.
| Bookmarks |
