Old 10-23-2015, 09:13 PM   #1
BigDan3131
BigDan3131's Avatar
Caster Changes
Since aftermarket control arms now have the needed caster added to them can I just install the uppers at this time? What will happen if I don't replace the lowers at the same time?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-24-2015, 08:42 PM   #2
PGSigns
PGSigns's Avatar
Re: Caster Changes
I think they are adding the caster to the lowers. The order that you do them is not to important as long as you get it aligned after the change.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-26-2015, 10:04 AM   #3
Custom 68
Custom 68's Avatar
Re: Caster Changes
The ones from CPP add caster with the upper ones. I have only swapped my uppers.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
