Old 10-23-2015, 09:34 PM   #1
jweb
jweb's Avatar
Fuel trim and running issues
Just got my LS1 going and having some issues
Bank 1 STFT 10%
Bank1 LTFT 25%
Bank 2 STFT 0%
Bank 2 LTFT 5%
Seems to be running rich, fuel coming out the exhaust and really poor acceleration.
Any ideas?
If it helps I have a homemade intake, shorty headers, full exhaust and new O2 sensors.
jweb is offline   Reply With Quote
Old 10-24-2015, 01:34 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel trim and running issues
Any codes being thrown? Do you have a log?
Bank one is essentially saying that "right now" your adding 10%, and "in general" you'll be adding 25%...which is a high commanded fuel trim.
The fact that the other bank is essentially perfect, says that it shouldn't be a global problem. My first inclination is to look for a major exhaust leak (false lean condition) causing it to dump extra fuel.
Those symptoms could also be indicative of a stuck or leaking injector (tho it would be more common to see negative fuel trims in that case)
Those AD's have room issues...where is your MAF located in that homemade intake?
And the #1 question I ask on virtually every post; who tuned it?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-24-2015, 11:58 AM   #3
jweb
jweb's Avatar
It had a lean bank 1 code. Thought I fixed it when I found a plugged injector.
No log my scanner doesn't save anything.
Attached a picture of my intake setup, MAF should be far enough away from the throttle body and filter. Filter is just under brake booster
Mail order tune, I want to have it dyno tuned but it's $550 and want to make sure I have any issues sorted out so I don't pay twice.
Old 10-24-2015, 03:39 PM   #4
jweb
jweb's Avatar
Also just checked my fuel pressure and have 50-55 with key on and 70 while running. Is this OK?
Fixed this problem with a new filter/regulator
Now I have high ltft on both sides.
Old 10-26-2015, 01:32 PM   #5
Hart_Rod
Hart_Rod's Avatar
Did you change your injectors or are they factory?
Hart_Rod is offline   Reply With Quote
Old 10-26-2015, 03:13 PM   #6
jweb
jweb's Avatar
They are stock, I have tried several things with no luck. I am now wondering if a small exhaust leak is enough to cause a problem
Old 10-26-2015, 03:52 PM   #7
Hart_Rod
Hart_Rod's Avatar
Yes
Old 10-26-2015, 10:30 PM   #8
aknovaman
Cool Re: Fuel trim and running issues
I have buddy in portland. if you need help troubleshooting it as he has hpt tuners and is very capable of helping fix the issue. Pm me if you want his contact info. He tunes turbolsx cars and hemi cars.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
