Old 10-24-2015, 01:34 AM   #1
Henney
CPP Brake Conversion
I've installed the CPP under cab booster/master/proportioning valve setup. I also have the residual valves installed and the system plumbed and bled. Been driving with it daily for a few months now and every now and again if I get on the brakes real hard they will hang up for 20-30 seconds before fully releasing. It doesn't do it all of the time and I can't figure out what's causing it. It also seems like it's only the fronts hanging up and more specifically the front left. Any ideas?
Henney is offline   Reply With Quote
Old 10-24-2015, 02:08 AM   #2
yossarian19
Re: CPP Brake Conversion
A hanging brake can be:
Stuck caliper (piston or slides)
Misadjusted booster rod
bad brake hose
and maybe some other stuff I'm not thinking of.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 10-24-2015, 02:27 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Unless the master is BELOW the caliper bleeder you do not use a residual valves. The purpose of a residual valve is keep fluid in the line and will do exactly what you describe.
Of the above things to check the booster rod is the most common problem we find with hanging brakes,
dwcsr is offline   Reply With Quote
Old 10-24-2015, 04:27 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
here is a diagram that explains when to use a residual valve
Old 10-24-2015, 02:18 PM   #5
OrrieG
OrrieG's Avatar
I had the same issue with my front discs during the first install, rod between pedal and mc was set to long keep pressure on the front discs which would heat up and lock. There should be a little play when you push the brake pedal before the rod contacts the mc or vacuum booster. I assume you are running a pedal return spring so you get full return. Adjust it at normal operating temps to allow for expansion in the rod.
OrrieG is offline   Reply With Quote
Old 10-24-2015, 02:30 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
There is supposed to be 0.020 clearance between the booster rod and the master. Rarely have I seen an aftermarket booster pin adjusted correctly out of the box.
Old 10-26-2015, 10:35 AM   #7
Henney
Thanks Guys. I'll take a look at the clearance. We've adjusted it a couple times so I think its correct but...
Old 09-11-2016, 11:29 PM   #8
NW Task Force
NW Task Force's Avatar
Question Bleeding brakes on an under-cab style brake booster
I have a 57 Chevy pickup with an aftermarket CPP style brake booster/master cylinder mounted on the frame (below the driver's side floor). I have tried many times to bleed the system of air and get the pedal firm before coming in contact with the floor. It seems no matter what I do, the pedal always reaches near the floorboard to stop the truck normally. Panic braking WILL NOT lock up the brakes. I find this unacceptable, especially if I have to emergency brake the pickup. I have heard stories that under cab style master cylinders are a pain to bleed the air because they are down low and air gets trapped. I am running residual valves for disc brakes (front & rear) also. Any tips, tricks, or things I should do to positively bleed the air out? Thanks
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 09-11-2016, 11:45 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Bleeding brakes on an under-cab style brake booster
2 wheel disc, 4 wheel disc? size of master? how far down does the pedal go before it does brake, will it pump up once and brake better?
Old 09-12-2016, 07:06 PM   #10
NW Task Force
The truck is 4 wheel disc, about a 9" booster, and the pedal levers down several inches until you can feel resistance. The final 1" before the floor seems to actually engage the brakes.
Old 09-12-2016, 09:56 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
increase the master size to 1.125 or 1.25,
Old 09-13-2016, 09:45 PM   #12
NW Task Force
I recently dug through some old receipts. The booster/master cylinder kit is made by TCI (TOTAL COST INVOLVED engineering). It appears the booster is a 7" and the kit was specifically designed for 55-59 task force trucks. I checked online, they still have a website but do not sell brake kits anymore. I did notice that another company online sells their various brake kits, including the 55-59 trucks. The actual master cylinder is stamped in the cast iron and says: MADE IN THE USA. Your size recommendation of 1.125 or 1.25 is in reference to what? The bore diameter of the master cylinder piston? Also, when a person buys one of these boosters/master cylinder kits..... is there a difference between all 4 discs vs drum/disc?
Old 09-13-2016, 10:27 PM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
Yes cylinder bore size and yes to disc/drum and disc / disc being different for master and prop valve.
Because you have 4 wheel disc it takes more fluid volume to move the disc pistons than it would to move 4 wheel cylinders or disc/drum, this drops the line pressure but can be made up with a dual diaphragm booster.
Some of these companies use 1" master cylinders for Disc Drum 1/2 ton trucks. I think you will be happier with a 1.125" , it may take slightly more pedal effort but it will be closer to the top of the pedal when it engages.
Old 09-13-2016, 10:55 PM   #14
Rude Dude
Rude Dude's Avatar
If running four wheel disc make sue they sent you the right proportion valve one is for disc/drum, the other is disc/disc combo.
Inline proportion valves are rated at 2 psi front or rear Disc (blue) and 10 psi rear drum (red) these are normally one way check valves, keeping fluid pressure to caliper.
Rude Dude is offline   Reply With Quote
Old 09-13-2016, 11:00 PM   #15
Rude Dude
Rude Dude's Avatar
Good info here
http://www.how-to-build-hotrods.com/brake-system.html
Old 09-13-2016, 11:10 PM   #16
NW Task Force
Thanks for the feedback guys! The booster did not come with a pre-set PV. I ended up building my own system by using a universal wil-wood adjustable PV installed on the inside frame rail. I made sure to also plumb in 2 residual valves for disc/disc (2psi rated). According to TCI, the master cylinder is called out as a "corvette style". Could I go online and order any corvette master cylinder that has the larger piston like you are suggesting?
Old 09-13-2016, 11:22 PM   #17
Rude Dude
Rude Dude's Avatar
Corvette style usually means 77 to early 80s
Old 09-13-2016, 11:40 PM   #18
dsraven
if you bought a kit, all inclusive, from a company then the kit SHOULD be set up properly. that said i am sure guys will have had issues with different companies. but, lets rule out any glitches you may have unknowingly brought on upon assembly.
I don't mean to step on anybody's toes here, just don't know your skill level. bear with me please. here are a few thoughts
check to make sure ALL the linkages, pivot points etc are in good shape and adjusted properly so there is the absolute minimum of slack or wear at every pivot or joint.
if there is a crank set up in the system make sure it is adjusted properly ie: the crank swings from, say, the 8 oclock position to the 4 oclock position and the 6 oclock position is the midway point of that arc. if that same set up were to go from the 6 oclock to the 2 o clock, and 6 oclock were the midway point of the arc, then there would be mechanical advantage lost. check it out with a paper. draw a circle with numbers like a clock. now draw parallel vertical lines from one side of the clock to the other at each number on the clock. now see how much horizontal movement you get when you move from 8-4 and compare with the 6 to 2. when you go from 6-2 you actually go backwards a bit at the end.
check to ensure the master cylinder pushrod is adjusted properly.there should be a minimal amount of slack BUT some slack there. if no slack the system is unable to fully release all the fluid when the foot comes off the pedal. if too much slack then you lose effective pedal travel when you first step on the brakes, ie: the first bit of pedal does nothing until the pushrod actually touched the pistons in the master cylinder. the manufacturer should have a tolerance but at least leave a bit of room there. check other manufacturers and take an average at least.
check to see if you have the proper amount of pedal travel required for your set up. a longer or shorter pedal lever can change things. a pedal arm bent to fit a floor modification can change things. the cab mounts can change things.
check to see if the lines going to the brakes from the master cylinder are connected to the proper set of brakes, fronts and rears
check to ensure the brakes are all assembled properly and working as they should.
check to see if you need residual valves for your application
ensure the system is completely bled of air. a power bleeder is an option if you are having trouble. bleed the furthest caliper from the master cylinder first
try it again
hope it works out for you
Old 09-13-2016, 11:42 PM   #19
dsraven
check out summit racings brake tech. it talks about master cylinder size and brake pressures etc. larger bore can mean less pressure in the system if it is too large because the pedal effort becomes greater.
Old 09-14-2016, 10:03 AM   #20
dsraven
if you can see into the master cylinder, have a buddy step on the brakes while you look into the cylinder (safety glasses). when the pedal is first applied there should be a little "disturbance" of the fluid in the reservoir. that is actually some backflow of fluid because the hole in the bottom of the reservoir is open to the bore of the cylinder and is forward of the piston at this point. this is what allows fluid to return to the reservoir after a brake application. as the piston is moved forward in the bore fluid travels up into the reservoir because it is easier than pushing the brake caliper pistons out. when it stops backflowing (when the piston travels past the bore supply hole), like very shortly after the pedal is depressed, the fluid is directed to the brakes and the further down the bore that the piston travels (more pedal travel) the more brake application. one thing to mention here is that a larger bore master cylinder is going to apply the brakes quicker (less pedal travel) because it dispalces more fluid per stroke, but the pedal effort will be more to get the same amount of pressure in the system once the brake pads have fully contacted the discs. a smaller bore cylinder will displace less fluid, so more pedal travel for the same amount of caliper piston movement, when the brakes are applied compared to a larger bore master, but once the brake pads contact the discs there can be more system pressure applied with the same pedal effort. when the brakes are released there will likely be another "disturbance" of the fluid at the very end of the pedal travel and that is the pressure in the system coming back into the reservoir. now, you may ask, if you step on the pedal and push X amount of fluid to the brakes, then release the pedal, all that should come back is the same X amount of fluid. well, that may be true but if the master cylinder was just a cylinder with no way for extra fluid to enter for top up, then as the brakes wear your pedal would get lower and lower to the floor because the brake calipers or cylinders have to be further out in their bores and so they displace more fluid. also, as you use the brakes when driving the fluid expands so the master cylinder has to have a way to get rid of the larger volume of fluid so the brakes don't stay partially applied. (this can happen when residual valves are used when they are not technically called for because they hold a couple of psi pressure in the system when there is already some pressure in the system from gravity).extra fluid is allowed back into the reservoir at the end of every brake application because the piston is allowed to come further back in the bore than the supply hole from the reservoir. that is whay pushrod length is critical. if the pushrod is too long the piston can't come back all the way and can cover that hole. if it is too short then you lose pedal travel taking up the slack inthe system before the pushrod contacts the piston in the bore.
make sense? hopefully not totally off base with the questions.
another thing I forgot to mention on the previous brake check blurb is to check the booster bracket and all linkage points for flexing when the brakes are applied. some mechanical advantage/pushrod travel can be lost that way plus, metal only bends so many times before it cracks.
Old 09-14-2016, 10:11 AM   #21
dsraven
forgot to say " as you use the brakes the fluid expands from heat"
I know, boring guy, we all know this stuff.
a larger booster or a dual booster allows for a larger bore master cylinder. all good until your engine stalls while driving, then you have one good brake application before it is really hard to apply the brakes due to large bore master cylinder.
some guys will use a hydro boost in tight applications because of the larger master cylinder sizing allowed. they have a pressure reservoir in the hydroboost that also allows for a single brake application should the belt break or the engine stall.
i am sure somebody on here has some pics of a hydroboost install in one of these trucks.
Old 09-15-2016, 12:04 AM   #22
NW Task Force
I went out into the shop tonight and decided to investigate some more on the master cylinder. After wiping it clean yesterday, two areas had pooled up with drips over night. One was directly below where the master cylinder mounts to the booster and the other was directly below on the center section of the MC. I ended up taking off the MC and noticed fluid residue at the bottom of the rear piston bore. I also noticed fluid was weeping around the edge of the MC cover lid. The entire MC/booster unit has only 3 yrs of use on it (occasional car shows), that's it. It's hard for me to believe the MC is leaking from the piston. The bore of the piston is indeed the standard 1". The casting on the MC is 29969, which indicates a standard GM master cylinder used on corvettes. Apparently this number is generic because it does not specify disc/drum, disc/disc online. I attached some pictures for clarification on leaks areas.
Should I buy a new MC with the 1-1/8" piston and re-seal all the brake lines attached to it?
Note: No fluid/residue was found inside the vacuum line to the booster and the pin area of the booster to MC.
Old 09-15-2016, 12:37 AM   #23
dsraven
could be just the lid leaking. does it look like there is a pin hole in the casting?
if it was me I would probably take it apart and check what you have for guts inside and also see if there are any pit marks in the bore. but if you are doing that then you might as well put a kit in it, and if you are doing that then you might as well just get a rebuilt that is specific to a vehicle with disc/disc brakes. that way you know the master is correct at least. you could also get a used one with the large bore from the wrecker just to try it but that is sort of a waste unless you keep it installed after the trial, in which case it isn't a waste. on and on and round and round.
brake fluid likes to trap and hold onto any condensation etc, so the existing cyl may have some pitting even though it has seen little use. one of the downfalls of having the thing under the floor close to the road is that it also is out of sight out of mind. it kinda looks like it has seen some moisture. another thing to check for is fluid inside the booster from a possible leak at the bore of the master. I usually like to use a plastic straw or cable tie to check because they are not likely to cause damage to the diaphragm inside the booster. the pics kinda look like the bore was leaking but then there is also fluid under the cap gasket area so that may be the problem and it just ran down from gravity. same as the leak partway down the casting.
as far as going with a larger bore size, it is hard for us to know because we don't know what kind of pedal effort was required for an emergency stop with the current cylinder set up.
did you also have a chance to check all the linkages etc and the pushrod clearance?
Old 09-15-2016, 04:01 PM   #24
dwcsr
Hollister Road Co.
dwcsr's Avatar
I would go with the 1.125" bore I think you'll be happier with the pedal. It will feel slightly harder to press but not significantly. M39052 over on rockauto.com is about $28.
Old 09-15-2016, 07:03 PM   #25
dsraven
yup, i'm with DWCSR, stick a new one in and, for that price, if it doesn't work out you are only out a few bucks and some time. probably be fine though. make sure you bleed it really well and adjust the linkages.
