Old 10-24-2015, 04:24 AM   #1
Dans1960SWB
Rear cross member???
Ok I just bought this 60 SWB. It is missing the motor and trans. It had a three on the tree. I want to put in a turbo-350 in it. Can I use a cross member from something else? Or can I modify this one? Thanks in advance!!!
Dans1960SWB is offline   Reply With Quote
Old 10-24-2015, 12:39 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Rear cross member???
Original automatic crossmembers for those X-frames are tough to find. You can fabricate one up from something like this; just angle cut to fit.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 10-25-2015, 12:01 AM   #3
Captainfab
60-66 Nut
Depending on how soon you need a trans crossmember, I may be able to supply you with a bolt in unit.
Old 10-25-2015, 12:07 AM   #4
Dans1960SWB
It won't be for a while. Truck won't be to be before Christmas or longer..
Old 10-25-2015, 12:25 AM   #5
Captainfab
60-66 Nut
I should have a sellable unit by the end of November, maybe a little sooner.
Old 10-25-2015, 04:08 AM   #6
Dans1960SWB
Ok keep me in mind...
