Old 10-24-2015, 10:04 AM   #1
Project86
custom dash im working on
I got tired of having all non working factory gauges and some cheapo aftermarket.
Using sheet metal it took me roughly two hours of trimming and fitting to get it to look decent. I will be redoing it especially the gauges to the left to make them more even.
I have since then added an automated fuel level gauge to the bottom right
Also made a radio block off plate for my line lock switch and fuel pump switch
Project86 is offline   Reply With Quote
Old 10-26-2015, 04:12 PM   #2
Shugalou
Shugalou's Avatar
Re: custom dash im working on
Cool didn't know you make this piece.
Might look cool to have it water transferred with some crazy pattern...or the standard carbon fiber.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 10-26-2015, 07:36 PM   #3
Project86
It's not the best. But when I redo it I want to block off the entire cluster. I wish I could find a template I could print out and cut it perfect.
It's not perfect but better than what I had and everything mounted solid.
Still need my trans temp and pressure gauge
Old 10-27-2015, 10:11 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
Are you putting in a radio?AC work?
I have an aftermarket radio where the vent goes if your not using AC.
I'm thinking to move the heat down to the old radio spot too.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-27-2015, 11:42 AM   #5
Project86
No a.c. no heat no radio, power steering, nothing
My truck is a drag truck project slowly getting there
Old 10-27-2015, 11:46 AM   #6
Project86
Here's my radio delete. Before I did the gauge cluster
