![]() Join Date: Oct 2013
Repairing Deluxe Heater Levers Help
I am repairing deluxe heater levers, two of them appear to be broken where knob fits. Can the heater and defrost levers be interchanged, e.g. if I find a good replacement heater lever can I use it in the defrost position?
Can the knobs be removed from levers without breaking or if you need knobs do you need to replace lever and knob as one piece? thanks, Les |
Re: Repairing Deluxe Heater Levers Help
I have these levers and knobs left over from my project if you're interested. I believe the two outside ones interchange and the middle one is different.
I changed mine last year with a repair kit I got from LMC. I think it was made by Old Air or something like that. The new levers were stamped steel instead of pot metal and came with the knobs, bushings and retainers to reattach the cables. It was easy to install and works fine. Like the above poster said I believe that two of them are the same and the other one is different.
#4 | |
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
![]() Join Date: Oct 2012
I have used the ones from Classic Parts also, and worked just as well. No more than these are unless you are on a super tight budget I'd just order new.
Thanks everybody for the help.
TMCK your photos raises another questions, were all the year knobs labeled with fan, def, etc? Yes, interested in your extra parts, mine is 64 to 66 controls. Les |
The knobs in the picture are from a 65 GMC.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Sometimes the same parts are less expensive at:
http://www.classicparts.com/Heater-P...oducts/214/3/0
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
