![]() Join Date: Jul 2001
How do ?
Are the front body mounts on a Suburban cab the same as a truck ? I'm talking about the platforms that hang off the frame....are they in the same place on both truck and Suburban frames ?? What about the rear ? Does a 'burb' have 6 or eight mounts ? The reason I ask is I want to put a Suburban body on a 1-ton frame. Thanks for the input. brad moore.
1967 GMC 3500 lwb dump flatbed project 1969 GMC 2500 1979 GMC 7000 fire crew truck w/water pumps 1982 C/30 Cummins NV5600 Crew Cab project Last edited by wbmoore; 09-15-2003 at 09:16 AM. |
The rubber mounts are different than my 3/4 pickup. They are shorter and may be spaced differently. Not sure on the number but I will be under my burb in the morning so I'll check it out. I will let you know.
Bob Chayer 71 3/4 ton 4X4 Suburban ![]() |
![]() Join Date: Mar 2000
There are a total of 6 body mount positions per side on a Suburban or Panel, all 1967-72 Suburbans 1/2 ton & 3/4 ton, 2wd & 4wd and all 1967-70 Panels 1/2 ton & 3/4 ton, 2wd & 4wd use these same body mounts. These body mounts are not the same as a pickup except for the 2 at the very front on left & right side. The radiator support mounting kits are all the same whether its pickup, Suburban, Panel, Blazer, Jimmy with 2 styles available 67-68, & 69-72.
We carry all of the body mounts, if interested you can find them here http://www.gmcpauls.com/rubber_&_weather_strip_21.htm GMCPaul |
thanks guys
Thanks for post and personal email.
Bob |
Re: Suburban body mounts
TTT for post support Posted via Mobile Device
Bob |
