10-24-2015, 03:59 PM | #1 |
What steering wheel is this?
Can anyone identify the steering wheel in this truck? I like the style. It's a toss up between purchasing a stock wheel or finding one of these.
Thanks for any help. |
10-24-2015, 04:01 PM | #2 |
Cruzzzn' Vet
Re: What steering wheel is this?
Looks like a Tri 5 wheel
10-24-2015, 04:28 PM | #3 |
Hollister Road Co.
or impala
10-24-2015, 04:54 PM | #4 |
It's a 59 impala wheel. They are available from aftermarket vendors. I have an original I plan on running in my truck.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
10-24-2015, 04:59 PM | #5 |
10-24-2015, 05:13 PM | #6 |
I test fitted mine on my 59 column and it seemed to fit good. I also tried it on the 78 Chevy van column I plan to use with the camaro clip and it seems like it will fit once I grind off the small lip at the bottom as the transition on the van column is slightly smaller. Splines are all the same.
10-24-2015, 07:07 PM | #7 | |
10-24-2015, 07:09 PM | #8 |
[/QUOTE]
Looks good btw |
10-24-2015, 07:54 PM | #9 |
Thanks. I plan to get it painted gloss black once I finish up my interior. I think it has a slightly more custom flavour than the stock truck wheel.
10-24-2015, 08:25 PM | #10 |
They are a great looking wheel when you find a nice one. The one in your photo has an aftermarket bullet in the middle of the horn button.
10-24-2015, 09:26 PM | #11 |
The wheel may be hard to find. 58 through 62 or 3 were very similar, that may help your search.
10-24-2015, 09:44 PM | #12 |
Moderator
They are reproduced, and, they now make them in the original 17" , and a smaller 15" size.
http://www.classicindustries.com/pro...rts/b9163.html http://www.speedwaymotors.com/15-Inc...eel,58574.html |
10-24-2015, 11:12 PM | #13 |
1962 bel-air... with some kinda wheel center aftermarket Mod
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
10-25-2015, 09:05 PM | #14 |
Thanks for the help guys. I found the aftermarket ones once I got the info on what wheel it actually is.
Aftermarket may be the way to go, since it isn't going into an impala, no need to get a 'correct' stock one. |
