Automatic to Manual/death to rice rocket
I want to go from an automatic tranny to a manual in my 67 short step. I know i will have to fab up the cluch peddle and make a hole in the floor for the shifter. But I am sure there will many more things to change that I am not thinking of. Will i need a new/relocated crossmember, bigger trans hump in the cab, or anything else?
Also what trans would u guys go to. Im running a 350/350. I dont know if it would be possible but i think it would be kick a$$ to run somekinda 5 speed something to help me go fast. One of the main motivations for this is my friend has 03 civic and we raced a while back when I had a 327, and he smoked me, I really want to beat that little rice rocket and i know u guys want me to as well. thanks ![]() |
clutch reservoir is something else. get a corvette 6 speed. kick ass
70 longbed 496/th400/Ford 9" |
Formerly yellow72custom
For drag racing, a automatic is better IMO. Go to the strip and see what most guys are running.....it will be an automatic. If you want to spank rice rockets, a 350/350 isn't a bad combo. If you want to go fast, do some motor mods, or install lower rear end gears.
Anyway, driving a manual tranny is fun, and if you can shift them fast, they will run. Plus you don't need to use a higher-stall converter for a larger cam as you would on a auto. You can rev the engine to any speed you desire and dump the clutch. You can get a 5-speed out of a later model P/U, or even a six speed. I know of one board member that has done the 5 speed swap (Huck), crazy longhorn is using a Richmond six speed, and another member is using a T56 six speed out of a Camaro.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
2 tons of fun
pphatbasstard,
This Tremec is a nice bullet proof 5-speed. Cya....Lumpy http://www.5speedtransmissions.com/gm_3550_package.html
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H Three Rivers, Ca Pics at: http://www.cardomain.com/id/lumpy454 |
Just get the clutch pedal and linkage assembly from a 67/72 truck . Place an ad in the parts page alot of members have converted to auto so you should be able to get almost all the parts you need for a reasonable price . You may need a high hump also it may have a small cover located on the driver engine side firewall with two small screws . That cover is what hides the hole for the clutch rod . Clutch rod to tranny you may have to fabricate .
thanks guys, what bout the crossmember will that need to be changed? and my driveshaft lenght will be different ass well to huh? thanks
