Old 10-25-2015, 11:51 AM   #1
Mthumphrey
Mthumphrey's Avatar
Chevy 250 - Clifford - Edelbrock Linkage Help
Installed a Clifford intake, Clifford shorties and a Edelbrock 400 on my Chevy 250/ 66 C10 Long Bed. Looking for pictures and ideas on linkage set-ups. Any help will be appreciated!
Mthumphrey is offline   Reply With Quote
Old 10-25-2015, 03:33 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Chevy 250 - Clifford - Edelbrock Linkage Help
I converted to a cable setup using Lokar. Mounted the carb with the primaries towards the radiator.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-25-2015, 04:22 PM   #3
Mthumphrey
Mthumphrey's Avatar
Thanks TJ! I need to play with it more. The adapter I have only allows the side set-up. Do you mind shooting a picture of your set up?
Old 10-25-2015, 04:30 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Here's the best I have. lol Motor has been gone for some time.
Old 10-25-2015, 04:32 PM   #5
Mthumphrey
Mthumphrey's Avatar
Thanks! That helps!
Old 10-25-2015, 04:34 PM   #6
Mthumphrey
Mthumphrey's Avatar
What model Lokar is that? Recall?
Old 10-25-2015, 07:49 PM   #7
slepysal
slepysal's Avatar
I'm running a two barrel holly on mine. I used a Spectere cable and brcket that I got from CSK ( now O'rielys) and a no name pedal that I got from ebay
This is how I set mine up :
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-25-2015, 08:57 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
Here's the part #....these are the old ones. I don't know if they have changed.
Throttle cable bracket and springs for carb:
SRK-4000
Here's the throttle cable:
Its 24" so you'll have to cut it down to fit which is pretty easy.
TC-1000U
And the pedal:
BAG-6149
I'd go to their sight Lokar.com and check these things out so you can see some pictures.
Old 10-26-2015, 12:54 PM   #9
Mthumphrey
Mthumphrey's Avatar
Thanks TJ!
Old 10-26-2015, 12:56 PM   #10
Mthumphrey
Mthumphrey's Avatar
Looks good Slepysal! Thanks!
Old 10-26-2015, 02:09 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Yer welcome! Here's a video I did for another guy on how to install:
https://www.youtube.com/watch?v=nPuQXmdrjEk
You can mount your carb the same as mine and install things this way.
