Old 10-25-2015, 01:58 PM   #1
Nitis
Nitis's Avatar
windshield wiper help/questions
Allegedly el nino is coming gosh we need it bad. SO with that
1 I put new blades on mine last year but they are just ho hum on how they work is there somegood replacement assemblies you recommend that might work well
2 My switch is kinda haywire. Sometimes it works fine but most times I have to push it in as to acuate the washer in order to get the wipers to wipe. So best guess wiring messed up or bad switch?
Nitis is offline   Reply With Quote
Old 10-25-2015, 02:26 PM   #2
80ids
Re: windshield wiper help/questions
I replaced my blades with aftermarket OE style, think they were trico. Will get you the info Monday when I get back to the shop.
Most likely your switch is messed up.
1967 Chev C10
Short Box Step Side
250 CID 3 on the tree
Owner/Operator at Upper Gage Garage
80ids is offline   Reply With Quote
Old 10-25-2015, 02:30 PM   #3
Nitis
Nitis's Avatar
looks like the switch runs about $40 so not breaking the bank but cost enough to want to be somewhat certain
I am thinking I may need new arms to its like there isn't enough tension against the glass if that makes sense
Old 10-25-2015, 07:31 PM   #4
cdowns
cdowns's Avatar
Try cleaning your glass with bonami real good and lubricate the wiper towers so it sweeps with no resistance
Old 10-25-2015, 09:49 PM   #5
bretcopsey
On my son's 68 the only way to get the wipers to work at all was to push in for the washer feature. Last weekend I figured what the heck and pulled the switch from the dash then disassembled the switch. I was able to clean up the contacts with fine sandpaper and put it all back together-so far works like new and saved the $40 for something else. Took about an hour start to finish.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 10-26-2015, 09:50 AM   #6
80ids
Wiper Blades 33-150 (Trico) - Silver
Arms 51-250 (Trico) - Silver
1967 Chev C10
Short Box Step Side
Old 10-26-2015, 10:23 AM   #7
BrianG
BrianG's Avatar
sweet! I'm saving those for reference. And I'm assuming that those look like the original ones?
BrianG is offline   Reply With Quote
Old 10-26-2015, 12:00 PM   #8
tdangle
tdangle's Avatar
This is what I bought for mine. New arms and blades. Here is the link Amazon.com: Trico 33-150 Classic Wiper Blade,... Amazon.com: Trico 33-150 Classic Wiper Blade,...
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-26-2015, 05:36 PM   #9
kehstr
kehstr's Avatar
my dad has a truck that he went through the hole wiper system, and they still don't work very well, he says they were that way when they were brand new. But i'm sure you could go through and make some kit that used newer electronics, so they would actually work, but it just sounds like a lot of work to me (but what isn't in a project)
kehstr is offline   Reply With Quote
