Old 10-25-2015, 06:28 PM   #1
weider1717
What would be the yellow paint mark on the water pump pulley used for?
Just curious as I noted it when I removed it. thanks
weider1717 is offline   Reply With Quote
Old 10-25-2015, 08:18 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: What would be the yellow paint mark on the water pump pulley used for?
Got a pic?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-25-2015, 09:02 PM   #3
79 Silverado/454
79 Silverado/454's Avatar
I would think that there should also be one on your clutch fan hub as well. IMO that is where it was lined up when it was originally assembled & torqued. An original unrestored Corvette I tore into a couple years ago was that way & that is the way I put it back when I reassembled it.
1979 C-10 Silverado SWB 454/400 Turbo
1987 GMC Jimmy Sierra Classic
2015 GMC Sierra SLT Z71 (Cayenne Metallic)
2018 GMC Denali HD Duramax (Red Quartz)
79 Silverado/454 is offline   Reply With Quote
Old 10-25-2015, 09:17 PM   #4
weider1717
see a picture I just posted i put the mark back when I put everything back on.
Old 10-26-2015, 11:00 PM   #5
weider1717
I'm sorry it was on the water pump housing where it mates up to the pulley. Not sure if the pulley was marked as I bead blasted and painted it.
So, this just indentifed that it was torqued? it was just one yellow small blop of paint just above one nut on the housing.
Old 10-26-2015, 11:30 PM   #6
enaberif
Its quite common for places that do a lot of assembly work to mark nuts that have been torqued down to spec by using a paint pen.
Even to this day I do this working on my own vehicles when I am doing a LOT of assembly on A LOT of things and could forget what I torqued and what I didn't.
enaberif is offline   Reply With Quote
Old 10-27-2015, 07:00 AM   #7
Keith Seymore
I'm sorry -I'm still not seeing a pic.
At this point it could be anything but without seeing it I would have to say either an alignment mark or paint dot denoting the fasteners had been torqued (as previously mentioned).
K
1979-1986
1986 - 2019
