Old 10-25-2015, 08:29 PM   #1
CDU71
champion radiator/Steam port line
Swapping a 5.3 into my 72 c10. I'm using a champion 3 row radiator, can i run my steam vent line to the heater port on my radiator? If not should I just run a tee and tee it into my top radiator hose?
CDU71 is offline   Reply With Quote
Old 10-25-2015, 09:10 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: champion radiator/Steam port line
I drilled a tapped a hole in my water pump on the boss by the top hose and plumbed it in there. But I've seen them ran like you are talking about to.
Old 10-26-2015, 12:40 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I used the heater outlet on my stock radiator. Actually that is an ideal place for it because it is above the coolant level.
LockDoc
Leon
Old 10-26-2015, 10:21 AM   #4
MalibuSSwagon
I also ran my steam line to the heater port on the rad. Used plumbing adapters from Lowes to connect the 1/4" line to the 3/4" port.
MalibuSSwagon is offline   Reply With Quote
Old 10-28-2015, 08:29 PM   #5
CDU71
Thanks for the help guys, got a barb fitting for free from the local parts store.
