Old 10-25-2015, 09:38 PM   #1
72 K20
72 K20's Avatar
Firewall oddity , dbl thick on right side
I noticed this on my 72 C20 today. The right side of the firewall is double thickness. It appears that the second skin was put on to correct the openings for the air conditioning. The truck was originally Ochre,, the inside still shows the original paint on the firewall. The spid shows air conditioning ,, the vin plate still has the correct rosette rivets.
Look at the pictures and tell me what you think took place.
Have a great day !! Tom
72 K20 is offline   Reply With Quote
Old 10-25-2015, 09:40 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Firewall oddity , dbl thick on right side
Looks like they fixed someone else's hack job. It is kinda strange though since the original color is on the patch...hmmm
Scott
sduckworth13 is offline   Reply With Quote
Old 10-25-2015, 09:51 PM   #3
72 K20
72 K20's Avatar
And the second skin is spot welded on ! I also found a spot by the E-brake cable that has a patch brazed on . And a spot just to the right of where the accelerator cable passes through the firewall that is brazed as well.
Old 10-25-2015, 10:40 PM   #4
rattle69
rattle69's Avatar
Must of fell of the assembly line and then was repaired by the factory. Really I have no idea. Good luck
70 lwb c-10
rattle69 is offline   Reply With Quote
