10-26-2015, 12:00 AM | #1 |
How much oil do I add ?
I have a 350 and I don't know what year the engine is, could be an 86. Chilton's says 85-86 is 7qt All others are 5qt. Dip-stick is damaged so that is not a good indicator. Is there an oil pan measurement which I can use or any other way I can tell. Have run it on 5qt. a few 100 miles. Will put in a new dip-stick but have to know if it is calibrated correctly. Thank You.
10-26-2015, 02:31 AM | #2 |
Re: How much oil do I add ?
Most 350's hold 5 quarts. If the motor is stock it holds 5 quarts.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
10-26-2015, 03:58 PM | #3 |
I know what you mean, and Chilton's is just plain wrong on that. They really f*cked me up one time when I used that capacity spec. 350's take 5 quarts of oil. |
