Restoring to stock valve cover
I am wanting to remove the aluminum valve covers due to poor quality and leaks and replace with stock ones. There is a "pcv-looking" device coming off left side valve cover going into carb. I am wondering what this is called shown here in this picture so I can pick one up and replace. Any ideas? TIA!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
Re: Restoring to stock valve cover
Guess - Flame Arrestor?
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
subbed
Figure out what you want--then figure out what you are willing to give up to get it. |
Just transfer it to your new cover.
It's an air intake to your motor. You need air in to mix with the fumes and be drawn out the other cover with the pcv. A thought though!! If you can't get those covers not to leak, you'll have more fun with stock covers. |
![]() Join Date: May 2010
Those are nice looking covers, have you tried a good quality gasket set?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
![]() Join Date: May 2013
I've used these on my last 2 trucks with success..
Fel-Pro VS12869T (rubber with metal insert to prevent over tightening)
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
For what it is worth, my '70 C-10 SBC 350 has the flame arrestor on the passenger side and the PCV valve on the driver's side; just like shown in your photo.
I like Edelbrock Gasgacinch for sealing these valve cover gaskets - follow their directions exactly - and if you need to remove your valve covers use a heat gun to warm it up first and a nylon pry bar and the cover will peel right off clean as can be... I vote to keep the aluminum covers as well unless they are warped... the bolt torque is only 3 to 7 foot pounds depending upon whom you believe - so they do need to be straight. (Wow; that motor is sano! Nice work!) Off topic so please don't comment in this actual thread to keep it on topic but the leg of my temp harness runs along the frame rail rather than above the driver's side valve cover like your has it - I think mine probably must be wrong judging by the rest of your install :-) |
Moderator
![]() Join Date: May 2007
^^^This
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
I couldn't find a replacement flame arrestor. I soaked in Evaporust to get back to bare metal. Cleaned up perfect. Classic Heartbeat carries the molded rubber hose.
If you are looking for a molded PCV hose for the RH side. Ecklers carries those pricey... https://www.ecklerschevelle.com/chev...1964-1972.html
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
| Bookmarks |
