Old 10-26-2015, 10:05 AM   #1
Myoldtruck
Myoldtruck's Avatar
Clutch linkage adjustments
Hello all. Ive had my c10 for 4 weeks now and looking to see if there is any adjustments to the clutch linkage I can do to make pushing the pedal down not so much of a chore.
On the short list im going to do: Grease the Z-bar, grease linkage shafts, Install correct frame return spring.
Ive also read that there should be about 1" inch of travel in the clutch pedal before any engagement, so the pedal travels some. Any thoughts on that.
Myoldtruck is offline   Reply With Quote
Old 10-26-2015, 06:04 PM   #2
Redline novdog
Redline novdog's Avatar
Re: Clutch linkage adjustments
Yes you lube everything,alignment could be a factor, but some depends on the pressure plate that is in the clutch asembly,
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
