Old 09-14-2003, 10:36 PM   #1
Bowtie468
Bowtie468's Avatar
dash removal ???
How hard is it to remove the dash in these (67-72) trucks ? Can someone give me the lowdown on it , like what has to be removed first, and what doesn't have to be removed. How many bolts hold it in and where are they located. I found a '71 at the salvage yard that i'll be robbing the front suspension/ disc brake setup off of for my 5 lug conversion. The guy told me to take whatever i want for $100. While i'm in there, i may grab the a/c dash if its not to much trouble.
Chris
Bowtie 468
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 09-14-2003, 11:01 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
I don't think its going to be all that simple. Might be some bolts but it's also welded in. There's some recent threads about ac dashes for sale. Maybe it was teeitup who had them or could tell you the specifics.
sameyrasmea72 is offline   Reply With Quote
Old 09-14-2003, 11:02 PM   #3
truckster
truckster's Avatar
I don't know the answer to your question, but I know the firewall on the factory A/C trucks is different.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-14-2003, 11:21 PM   #4
Shane
Shane's Avatar
- it bolts up to the side of the UPPER kick panel/under the dash - I think its two bolts per side, but not 100% sure
- then there are about a gazillion spot welds all along the top/front where the dash meets the front windshield pinch weld
-lots of folks unbolt the side fasteners and then cut all the way across in the area where the dash pad covers it ... lots easier this way
Hope this helps ...
Shane is offline   Reply With Quote
Old 09-16-2003, 09:25 AM   #5
Gee_Emm
Personally if your radio hole is not hacked I would take the AC dash out of the yard and use it for templates to cut the holes in your dash. It is WAY easier to do this then it is to cut and reweld the entire thing in. Also keep in mind that the heater box hole on the firewall has different shaped opening, try and get that piece to weld into your cab.
Gee_Emm is offline   Reply With Quote
Old 09-16-2003, 12:44 PM   #6
adamls
Gotta Startem Early
adamls's Avatar
I would take the whole truck for $100, take it home and experiment with it.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 09-16-2003, 02:57 PM   #7
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Let me tell you that taking the dash out of one of these trucks is not fun!! There are three bolts on each side. The bottom two are easy to get to, while the third and upper bolt is a bear unless the dash is stripped.
Now comes the fun part. About 40 spot welds across the windshield lip. I drilled them all out and still had to beat the crap out of the old dash.
I bought an AC dash off of teeitup for $30. He cuts them out so that the lip is still in good shape because he cuts out the windshield frame. I will just cut it close to the dash and grind the excess metal down to make it fit back in.
I would pass on it and find one for sale that someone already took out.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-16-2003, 08:15 PM   #8
RON WOODGEARD
Resident Young Old Dude !
There is a drill bit made to drill throuugh one side of the metal and welds and only leave a small drill hole in the other, ( in this case the dash) I bought one from a member here on the board, I don't remember who though, I cut out a A/c dash the hard way, and Would never do it again, The only reason I finished the job ( the next day to boot) is I'm stupidly stubborn, and had already paid the wrecking yard for it.
Ron
RON WOODGEARD is offline   Reply With Quote
