Old 09-14-2003, 11:07 PM   #1
72MARIO
72MARIO's Avatar
How to Drive a 3 on the Tree ?
I am going to go look at a 69 GMC for a Daily Driver. The only problem is that I dont know how to drive it It's a 3 on the tree, Um could some one help me out.
I have never driven a standard before. I will probibly be making it into a Auto with in the first Month of owning it. But I need to know how to drive it for now.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-14-2003, 11:11 PM   #2
krue
Designated A-hole!
krue's Avatar
To you and up is first, down is 2nd, away and up is third, away and down is reverse. Picture an "H" on the column and you'll have no trouble. Mash the gas and ease out on the clutch to take off. ONce you are rolling mash the clutch and shift, then let out on the clutch smoothly. Best way to learn to drive a stick!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-14-2003, 11:14 PM   #3
Phillip Johnson
Phillip Johnson's Avatar
If you can drive a 4 speed you can drive 3 on the tree. Basic H pattern. Pull shifter towards you and pull down for first, then 1/2 way up to neutral and push back and then all the way up for second. Then pull all the way down for third. Reverse is straight above first.. So easy my 80 year old mother could do it if she wasnt in a rest home! Good luck!
Phillip Johnson is offline   Reply With Quote
Old 09-14-2003, 11:14 PM   #4
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
It's pretty easy once you get the hang of it. Try to think of as if you took it right off the floor and stuck it on the column. Pull back and up will get you in reverse. Pull back and down will get you into first gear. Then shift forward and up to get second gear. Then still in the foward position shift down and you are in third. If you are familiar with a floor shift I think you will pick it up quick. If not it may take a few times to get it. Hope that helps some. Good Luck!!
-Ron-
OldSkool71 is offline   Reply With Quote
Old 09-14-2003, 11:14 PM   #5
krue
Designated A-hole!
krue's Avatar
BTW it's been 15 years since I drove a three on the tree, so I hope I remember it right!
www.daveramsey.com
Old 09-14-2003, 11:15 PM   #6
krue
Designated A-hole!
krue's Avatar
OOPS! Don't listen to me obviously I don't know my butt from a hole in the ground!
www.daveramsey.com
Old 09-14-2003, 11:16 PM   #7
gr8scott51
gr8scott51's Avatar
go slow
Shift slow. The old 3 speeds weren't built for racing. Practice before you hit the traffic. A little bit of gas, let the clutch out slowly. Remmeber to push in the clutch when you stop.
good luck, scott
if you decide to move it the floor, I have a Hurst Indy shifter.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-14-2003, 11:21 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't get frusterated. Do not let it sour you from all standards.
These old column shift trucks are flat worn out and shift like ass. A trip to the dealer will get you some new bushings for the shift linkage, that will remove the slop and make it a lot easier to drive for like 10.00.
A floor shift will shift much better most times.
Myself, three on the tree for me. It lets the wifey slide over real close, try that with a floor shift.
Old 09-15-2003, 12:15 AM   #9
Blue_71
Bloo
Blue_71's Avatar
towards you and up is reverse, straight down is first, up over and up is second, straight down is third. be very careful to follow the H patten, or be ready to get under the hood and wiggle linkages usually
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-15-2003, 01:38 AM   #10
pissonNOS
senior member
pissonNOS's Avatar
just curious as to what kind of three on the tree this is out of mine is the same way everyone else has discribed
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 09-15-2003, 08:52 AM   #11
72MARIO
72MARIO's Avatar
I am going to try it out. I think that If I change anything I will put the auto 350 in it. I have all the parts here from a Parts truck I have here.
Thanks for the help.
My Girlfriend would not let me put a floor shift in because she likes to sit in the middle.
2005 TAHOE DD
Old 09-15-2003, 09:08 AM   #12
CPNE
Resident Curmudgeon
CPNE's Avatar
My 12 yr old can drive a 3-on-the-tree. Has so since 10. It's a matter of coordination and patience. Coordination to get the gas/clutch feel down, and patience to shift smooth and easy. It ain't no 5 speed Honda Si, and can't be treated as such.
At 10 or so they understand this as the expection of speed and short-throw shifting isn't ingrained in the head. I'd hate to have had to teach him the gracefull nuances of shifting a 3-on-the-tree if he were 17-23 in age.
Assuming good bushings and linkage, if you shift it like Grandpa, it'll slide right into gear, if you shift it like a Grand Am, you'll lock it up often.
Remember, it's not the tranny and linkage at fault, it the nut behind the wheel!
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-15-2003, 09:22 AM   #13
SCOTI
SCOTI's Avatar
Remember, these old 3spds don't have a synchronized 1st gear. This means when you want to put it into 1st gear you must be @ a complete stop or the gears will grind. To make life easier on parts, always shift to 2nd gear just before going into 1st (it somewhat helps synchronize everything so theres less grinding).
Toward you & down is 1st. Away & up is 2nd. Away & down is 3rd. Toward you & up is reverse. Shift slowly between gears (just don't slam the gears anyway).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-15-2003, 09:29 AM   #14
CPNE
Resident Curmudgeon
CPNE's Avatar
Actually, starting in 69 the 3 speeds were syncro'd (definately by 71), it was 67/68 that didn't have this. Still good advice regardless!
Old 09-15-2003, 10:49 AM   #15
Class of 69
Class of 69's Avatar
Floor shift with a long handle that curves back on the seat
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 09-15-2003, 10:59 AM   #16
landon4421
Life is Good !
landon4421's Avatar
72MARIO, you beat me to this question ! I am looking at a truck with the 3 on the tree ! And it has been like 15 years since the Last time I ever drove one an I had totally forgot the pattern. Thanks for the post and thanks guys for helping me to remember the shift pattern ! Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 09-15-2003, 01:31 PM   #17
lukecp
Formerly yellow72custom
lukecp's Avatar
lol Class of 69
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-15-2003, 01:34 PM   #18
72MARIO
72MARIO's Avatar
I don't get it........... Must be somthing kinda Dirty.......
2005 TAHOE DD
Old 09-15-2003, 02:45 PM   #19
palallin
Humorous story about my changing my '67 from a PG to a 3 spd:
I had never driven a standard before, and I was sent out to "learn on the fly." After a day or two of practice, I felt confident enough to stop partway up a hill on a service road and try to get going up hill. I killed the motor. I tired again with the same result. And again. And again. And again. By the sixth time, I was at the bottom of the hill, but I couldn't get up it. By the ninth time, my battery had run down, and my starter was sounding very weak.
Finally, I had to swallow my pride and walk up the hill (with my girlfriend, whom I had been trying to impress) to a phone and call my dad to come give me a jump. (He had been against my switching to the standard from the beginning.) He showed up, and still the jump wasn't enough: the starter was trashed.
While Dad was berating me in interesting and colorful terms, I crawled underneath to attach a tow rope so that he could toiw me home with his big, '71 Impala. Then I got in the cab to steer. I had to take the truck out of gear, of course, so that he could tow me.
Then it was that I discovered that the transmission had been in 3rd gear all along . . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-15-2003, 02:59 PM   #20
JoetheMobster
Listening since '86
JoetheMobster's Avatar
Interesting way to save face!!
It took me a few tries to get in sync with the transmission when I got my truck - first 3 spd for me.
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 09-15-2003, 03:14 PM   #21
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I learned by doing it. Telling you won't help any. Have fun.
67Fleetsidedream is offline   Reply With Quote
Old 09-15-2003, 11:17 PM   #22
Eddie H.
Eddie H.'s Avatar
Damn, I guess I'm getting old. I learned to drive in a 1950 Chevy
with a 3 on the tree, and I remember taking my driving test in a red 67 Chevy C10 with a straight 6 and 3 on the tree. It was pretty new truck at the time.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-16-2003, 01:52 AM   #23
Hooter
My other Love
Hooter's Avatar
I enjoy driving a 3 on the tree, especially with friends who have never seen one before, they look at me in puzzlement when I drive my 71 chev van around, kinda funny actually
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-16-2003, 02:09 AM   #24
Phillip Johnson
It shouldnt take more than 2 min to figure this out. Just get in and drive
