10-26-2015, 11:43 PM | #1 |
Emergency brake / headlight on buzzer
I'm curious if anyone has adapted a warning buzzer to these trucks for the e-brake and headlight ? I have driven away more than once with the brake still on, and also left the lights on by accident. Our truck is a 70 K10 with sm465.
10-27-2015, 07:05 AM | #2 |
Re: Emergency brake / headlight on buzzer
When I was growing up, you could buy a kit at WalMart for a headlight buzzer. It plugged into the fuse box a few places and had a ground. Here is one from Summit in a kit
http://www.summitracing.com/parts/sd...FVMvgQodYHUHMA or a do it yourself instruction http://www.gmcmhphotos.com/photos/data/5969/test.pdf For E-brake, you could add something pretty easily. Just use ignition hot and a pin switch on the E-brake for ground.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-27-2015, 09:57 AM | #3 |
Thank you for the links, the headlight warning seems fairly basic. I thought about rigging something up , for the e-brake, but I hoped someone had done this, and had a thread already. I looked all over and came up with nothing. If we get time to fab something that works, I will show the procedure we use. Any and all suggestions are appreciated. This site is golden...Cheers Rick
10-27-2015, 10:04 AM | #4 |
Its been about 8 years since I did mine but I got the brake switch from a 80's truck and wired it to the dash light. My headlights are wired to a automatic switch that turns them off 30 sec after truck is shut off.
69 Chevy 4x4 383 Power |
10-27-2015, 10:13 AM | #5 |
Thanks, I like that idea, most newer vehicles have something similar. This truck will be my sons first, so I would rather not have to drive 20 miles into the booneys to jump start him and his friends.
