Heat Riser - 250
I have two exhaust manifolds, one the heat riser is fubar, the other it is functioning but the pin for the spring is all but rusted off. I was thinking of just eliminating the heat riser and pluging the hole. Will this effect cold starting, or just take a bit longer to warm up?
If you don't like this ![]() |
Post Whore
![]() Join Date: Mar 2013
Re: Heat Riser - 250
I left the heat riser stuck open all the time with mine and I had no problem. Even during the winter.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
The heat riser diverts exhaust to warm the intake manifold. A warmed intake helps prevent the vaporized fuel from condensing on the inside of the intake, especially true during hard acceleration when vacuum increases. Tom Langdon sells intake warmers that work with engine coolant. Use Landon's warmer with headers.
In warm climates the stock diverter is less important. My spring and holding pin were shot but it can be repaired very easily and new springs are sold by vendors. I'd try running it as it is now. If performance is poor then fix it. The flap inside might bang around a bit and be annoying.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 10-27-2015 at 03:24 PM. |
![]() Join Date: Oct 2012
If you want it to work, this would probably be the easiest way:
http://www.summitracing.com/oh/parts...make/chevrolet I just got one a few weeks ago, and seems to be pretty good quality. |
#5 | |
My truck ain't dead, it just smells funny. |
We drilled a hole and drove a new stainless pin into the hole. Then cut the pin to length.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7 | |
Cast iron is very, for lack of a better word, brittle. It can be drilled, but be very careful not to bang or whack it anywhere. Especially an exhaust manifold that has been through thousands of heat cycles. I ruined 2 trying to fix broken studs.
