Old 10-27-2015, 05:10 PM   #1
OlSmokey
One piece drive shaft install
I am having a lot of trouble getting the drive shaft in the trans. i have a th350 and i know all the measurements are right, but I can't get the yolk to line up perfectly with the transmission because it's going back and hitting the linkage at the differential. so i can't rotate it to get in the right angle. any suggestions or tricks?
OlSmokey is offline   Reply With Quote
Old 10-28-2015, 01:43 PM   #2
Fitz
Re: One piece drive shaft install
Put the rear on jackstands so you can turn the diff input shaft. The drive shaft should be 1/2 inch SHORTER than the distance from the transmission rear seal to the yoke on the diff as shown in the drawing. If it is, just slip the trans yoke in, rotate the diff until it matches, slide the shaft back to get the bearing cups into the saddles and bolt on the retainers. If it is the SAME length as the distance B6 in the drawing or just a bit longer, your driveshaft is too long and will need to be shortened and re-balanced.
Fitz is offline   Reply With Quote
Old 10-28-2015, 01:54 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
With the transmission in Neutral slide the yoke all the way onto the output shaft splines.
Since the transmission is in neutral you can rotate the shaft any way you need it. Then rotate it until the bearing cups line up with the saddles on the rear end yoke and slide the drive shaft rearwards into the saddles.
If you still can't get the drive shaft into the rear saddles... then like stated above, your dive shaft is too long.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-28-2015, 10:56 PM   #4
OlSmokey
oh wow, i didn't get any notification that there were responses. but thank you both for the responses I will try both of those things tomorrow!
Old 09-18-2016, 04:08 AM   #5
396C-10
7 years later??? LOL!
396C-10 is offline   Reply With Quote
Old 09-18-2016, 09:35 AM   #6
Gmc.guy
Gmc.guy's Avatar
Looks like you are almost 1 year later -- LOL
-Cody
Gmc.guy is offline   Reply With Quote
Old 09-18-2016, 12:55 PM   #7
OlSmokey
Yeah, almost a year later and I've been driving it good, and i did end up having to get the driveshaft shortened like .75" haha
