Old member
I'm looking at putting some kind of insulation under the hood to make it look a little better and to give it some stiffness.
What have the rest of you done under the hood and to help the stiffness of these model hoods? Please post pictures for idea's. I have the strips looking for a little more though! Something like this. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Hood insulation
I'm curious about this too.
While not all that relevant, I used a rubber mallet to get the original braces as close to the skin as possible, then cut my own rubber pads to slip between. It made a world of difference in the rigidity of the outer skin which used to flop around like a wet noodle running down the road. I considered using something similar to what you posted and reshaping to fit, but everything I've seen so far isn't large enough, and would probably need 2 spliced together, possibly ruining the rigid structure it had. |
Re: Hood insulation
i realize everyone here hates lmc but maybe someone else sells it
Old member
firedemon,
thanks that is a start. I never even thought about them. Man $179.00 for that is a little steep. I'll do some more looking ![]()
Re: Hood insulation
Here's mine. I did this about a year or so ago and still looks good to me. Lowes insulation, GM spray adhesive and trimmed out with black foam weatherstripping. Came out nice a clean and gives the hood some support imo. Also added cross brace for stiffness.
Figure out what you want--then figure out what you are willing to give up to get it. |
![]() Join Date: Sep 2015
Re: Hood insulation
I am so glad to see this post because I was thimking about asking the same question. I am looking forward to many choices and suggestions.
Larry 1970 Chevy Pickup C-10 Dodger Blue 305CI/Th400 auto trans Long Bed/Rally Wheels |
Old member
Ok I'm waiting guy's!
Re: Hood insulation
why would you want to insulate the hood? that only serves to keeps the heat INSIDE the engine compartment?
not bashing, just wondering. |
#9 | ||
"I ain't nobody, dork."
Re: Hood insulation
I was also wondering how insulation can add more "stiffness" to the hood?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#10 | |
Old member
![]() Quote:
Re: Hood insulation
Is the underside of your hood painted body color? I painted mine when I did it and I think that adds some "bling". It looks nice and is easier to clean up. I did paint my inner fenders and hinges black along with the core support.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Old member
Mine is all black under it. I did add the center peice to keep rain off the motor. I need to have it polished up good and that may be enough!
#13 |
Re: Hood insulation
i was thinking of some stainless panels I could attach to the supports an almost mirror finish maybe
#14 | |
Old member
![]() Quote:
#15 |
Re: Hood insulation
I haven't seen one or done it myself yet but I was thinking of spanning the distance from support to support with them meeting in the center of the support kind of like drywall on 2x4 and using some kind of tech screw or rivet in the support . I am a ways away from the point of under hood finishing touches though
#16 |
Re: Hood insulation
You could spray paint a bowtie on that middle panel if you're just wanting to jazz it up a little.
#17 |
![]() Join Date: Aug 2013
Re: Hood insulation
I went with Dynamite extreme across the entire hood then added a Dynapad hood liner over the engine. VERY stiff. I'm very happy with the outcome.
#18 |
Old member
Can you tell any difference in the temps under the hood? Does it seem to hold the heat in are is it about the same.
#19 |
Re: Hood insulation
Yes, big difference. Reflects the heat well. The Dynamat has some thermal properties in addition to the sound deadening and stiffing properties. The liner is pretty much like any other. I certainly have considered installing over the entire hood but it works just fine like it is. I was amazed at the difference.
