Old 10-28-2015, 12:24 PM   #1
mygirlz55
70's truck column vs van column
I'm in a bit of a pinch with our Camaro clipped 55 TF build. I've came to the point where I need to purchase a steering column and get the truck closer to being road ready.
I'm unable to find a van column to use and want to know if a 70's truck column will work for the time being. We don't have enough in the budget to afford a flaming river or ididit column right now, so I need to find an alternative.
I believe the only differences are the key switch and tilt but not 100% sure.
Has anyone installed a 70'S truck column in a Camaro clipped TF? if so, any help/pics would be appreciated.
mygirlz55 is offline   Reply With Quote
Old 10-28-2015, 12:32 PM   #2
bowt1ed
Re: 70's truck column vs van column
I am currently going through my second build of my 57 and for the last 20 years ran a 1980 Monte Carlo (non-column shift) tilt column. Perfect fit. I am now upgrading to an Ididit, but not due to issues with that setup. R/Jim
bowt1ed is offline   Reply With Quote
Old 10-28-2015, 12:58 PM   #3
mygirlz55
Thanks for the info
Did your truck have a camaro clip installed?
I'll keep the monte column in mind.
I will probably go with a column shift just to keep the floor area clear and make it easier on my daughters to shift.
Old 10-28-2015, 01:31 PM   #4
bowt1ed
Yep, 2nd Gen Camaro sub with SBC.
Old 10-28-2015, 02:01 PM   #5
HUSSEY
HUSSEY's Avatar
I have a van column I just listed on CL.
http://kansascity.craigslist.org/pts/5287472288.html
The only difference I'm told is the output shaft for a van column is a little bit longer.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 10-28-2015, 02:41 PM   #6
mygirlz55
Any pics of your Installation?
Old 10-28-2015, 03:03 PM   #7
Valarius_Starchaser
Valarius_Starchaser's Avatar
I have a 74 nova sub in my 57 TF with a 76 truck column in it no problem with angle no cutting of the shaft at all perfect
Valarius_Starchaser is offline   Reply With Quote
Old 10-28-2015, 03:20 PM   #8
mygirlz55
I think the Nova had a rear steering gear box. The camaro clip had a forward steering gear box.
Any pics of your setup?
Old 10-28-2015, 03:45 PM   #9
Valarius_Starchaser
A little dark and not the best angle only ones I have on my work computer worth showing
Not sure why they are so massive either.....
Old 10-28-2015, 04:02 PM   #10
mygirlz55
Looks about the same as the camaro sub frame. Did you have to put any support for the steering shaft?
Old 10-28-2015, 04:11 PM   #11
Valarius_Starchaser
I used the stock (to the column) loop bolt point under the gauge cluster and a kicker panel mount that I made out of an exhaust pipe the same size as the shaft and a piece of drop steel I picked up.
Old 10-28-2015, 04:12 PM   #12
oilslicktg
oilslicktg's Avatar
If you chopped the top, which it looks like you did, that bad boy looks great!
oilslicktg is offline   Reply With Quote
Old 10-28-2015, 04:13 PM   #13
Valarius_Starchaser
thank you yes it is a 3 inch chop still a long ways from the final stretch
Old 10-28-2015, 04:50 PM   #14
mygirlz55
still a long ways from the final stretch[/QUOTE]
Aren't we all?!?!
If you get a minute, could you post a pic from the steering gear box to the end of the column shaft? That's the part I'm the most concerned about. It looks like mine has too much of an angle to match up without some sort of extra joint in there.
And if I have an extra joint added, there would be no support in that area.
Old 10-28-2015, 05:15 PM   #15
Valarius_Starchaser
I will put one up when I get home nothing from that angle despite the wind and snow
Old 10-28-2015, 07:51 PM   #16
Valarius_Starchaser
Is this what you were after no additional joints but if you did add one towards the back you could make a bracket to keep it inline with the frame/add strength. if you want another spot I can gear up and go out again.
I clearly have yet to put my engine in (454) so I dont know how that will change things
Old 10-28-2015, 08:15 PM   #17
mygirlz55
Thanks. No need to go back out. I'll take your word for it. I'll just have to keep looking at the local junkyard for a truck column.
Old 11-12-2015, 09:57 AM   #18
Power
So you used a 76 Chevy truck column? The local yards in my area don't have anything past 89 lol anything else I can use?
Power is offline   Reply With Quote
Old 11-12-2015, 11:05 AM   #19
Valarius_Starchaser
The big thing that changes from truck to car ect is the overall length of the column body and the intermediate shaft they used the same steering backing plate for literally ever and if you wanted you could get a 2015 escalade wheel and put it in a 95 K1500 (ask how I know)
Anyhow there are plenty that will "work" but the intermediate shaft mounting may be different from the steering box
Basically measure and look I can check on length later on if need be
Old 11-12-2015, 11:35 AM   #20
59chev
59chev's Avatar
Just an FYI: 72 was the last year that chevy trucks had the ignition switch on the dash. After that, the switch is on the column. On the Chevy vans 78 I believe was the last year. The 70-78 Van columns interchange parts with the 72 truck tilt column.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 11-12-2015, 01:55 PM   #21
_Ogre
_Ogre's Avatar
nice chop job, do you have a windshield cut for that bad boy?
shop air compressor timer
Old 11-12-2015, 02:00 PM   #22
Valarius_Starchaser
I do not have a windshield cut the last guy I talked to quoted 1000 bucks
After that one I am considering doing it myself but with as many failed attempts I can imagine it may come to 1000 bucks either way oh well thats a problem for another day
Old 11-12-2015, 03:34 PM   #23
Purcell69
I used a column from a 1982 Olds Cutlass. GM G bodies will work. Mine is a column shift and was used with a 1974 Camaro clip and a Flaming River u-joint at either end. No pics though, since I swapped out the clipped Chevy frame for the Dodge 4wd frame.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 11-12-2015, 03:57 PM   #24
ptc
ptc's Avatar
Hey girlz55 - this is a typical GEN2 Camaro steering shaft setup (see photo) that you should be able to get away with any column. For the 55-59 truck I think you have to try and find the shortest column available which is about 26-28"????. It uses a joint at the column end and gets rid of the rag joint on the box and replaces it with another flex joint. You dont need a center support on this type.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
