Old 10-28-2015, 08:37 PM   #1
bbbc10
Diggin The SquareLife
fittings for hardline
im going to be running accuair setup and going to be mounting it in the bed of my truck and I want to run hardlines from the vu4 into my bed floor, an replace the leader hoses from the compressors to the tank with hardline and any other lines that will be seen in the bed, I need help finding fittings for the hardlines to do all this as im not finding anything online an im getting diff answers from ppl just wanted to get going in the right direction with fittings and where to get them....I want it to look like the setup in the pics
bbbc10 is offline   Reply With Quote
Old 10-29-2015, 07:12 AM   #2
PGSigns
PGSigns's Avatar
Re: fittings for hardline
One picture looks like they are using Swagelok fittings. https://www.swagelok.com/ The other is a straight flare fitting. If you have a Parker Store in your area they will have both types.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-29-2015, 07:38 AM   #3
biketopia
Like PGSigns said, if you have any hydraulic supply place near you I'd take a ride up there and they should be able to hook you up.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is online now   Reply With Quote
Old 10-29-2015, 07:45 AM   #4
Blown06
Blown06's Avatar
Like the others have said, top is push to connect fittings, middle is swagelok fittings and bottom is AN 37degree flare fittings.
I'm using AN fittings and the cheapest place I've found was www.anplumbing.com all are good fittings it just depends on the look you're after and budget.
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 10-29-2015, 08:05 AM   #5
biketopia
Those fittings add up quick don't they ??
I was going to put braided line and AN fittings on my bike oil lines a few years back and quickly was like NOPE, it's not that nice a bike ha!
Old 10-29-2015, 08:07 AM   #6
bbbc10
thanks for the reply guys!
Old 10-29-2015, 08:08 AM   #7
bbbc10
think im going to use the Swagelok fittings an maybe a few of the parker ones also
Old 10-29-2015, 06:37 PM   #8
PGSigns
PGSigns's Avatar
Parker makes all three styles and you should have one in your area.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-29-2015, 07:20 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Jimmy
Parker is my go-to, since its the only place you can usually handle the product before buying, order ANYTHING, and bring in old hoses/parts for them to match/replace/mockup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-03-2015, 11:19 PM   #10
pistonbroke800
pistonbroke800's Avatar
If you have an oilfield buddy he might be able to hook you up with some Swagelok stuff for cheap too. I have tons of it on my truck I just get it from work. Cant beat the price
pistonbroke800 is offline   Reply With Quote
