Old 10-29-2015, 03:40 AM   #1
seanrolandwood
Wiring harness choices
So I'm at the point where the wiring needs to be redone on my truck. The only useable parts of the old wiring worth saving is the tail light portion everything thing else needs to be redone as its been hacked into at one time or another...so in the cab I'm looking to replace the fuse block, all the wiring to gauges, ignition, and to the steering column. From the cab forward it needs it all.... starter alternator battery all the way to the head lights. Any suggestions as to who to use and why based on prior experiences would be greatly appreciated
seanrolandwood is offline   Reply With Quote
Old 10-29-2015, 04:29 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Wiring harness choices
The shop I used to work at used either American Autowire or Painless and I plan to use the Ron Francis Wireworks one instead since you can mount it anywhere. Mounting it that way means the wires route to it instead of from it like the others. I took my stock tank out to mount my stereo in but have since changed that to my center console so putting it behind my seat is perfect and much easier on my back and knees.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-29-2015, 06:37 AM   #3
PGSigns
PGSigns's Avatar
I have used the AAW kit in my 65 and liked the quality and the well thought out instructions. If the truck is stock with out a ton of upgrades a stock replacement harness from AAW or another vendor is a good option as it does not take long to swap. The last option is a nice original harness. The one I pulled from the last truck and sold was in very nice shape and had no mods during its life time.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-29-2015, 12:32 PM   #4
65sub
65sub's Avatar
I used the American Autowire harness and it was very easy to install
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 10-29-2015, 02:44 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
The best I've used on a consistent basis has been Ron Francis.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-29-2015, 08:32 PM   #6
seanrolandwood
So if i go with a aftermarket kit such as ron francis, painless, EZ, what compatibility issues am i going to find as far as hooking up to my stock steering column as i imagine everything else you run new...do they come with the correct connector?
Old 10-29-2015, 10:29 PM   #7
DPowers
DPowers's Avatar
I like these guys.
http://www.wiringharness.com/
DPowers is offline   Reply With Quote
Old 10-29-2015, 11:30 PM   #8
The_Hub
The_Hub's Avatar
http://www.summitracing.com/parts/aw...del/c10-pickup
I bought this one. American Autowire. Read all of the description. There is a ton of stuff and updates included in this one harness. Summit seems to have it for at least $50 less than everyone else too.
The_Hub is offline   Reply With Quote
