Old 10-29-2015, 09:38 AM   #1
kentucky_smith
What color scheme should my truck be?
I bought this 72 with this paint job. Not the best body work underneath, but there is metal there and not bondo. The bottom trim is there, but not the top, so the last painter put a pin stripe there.
I like the white and green two tone, but not against painting it solid green. Olive?
This winter I plan on redoing it back to sorta factory. Not a show truck, just cleaner. The SPID is long gone, did they paint them with the white stripe down the middle without the top trim.
Original paint under the hood:
kentucky_smith is offline   Reply With Quote
Old 10-29-2015, 09:56 AM   #2
68bowtie
68bowtie's Avatar
Re: What color scheme should my truck be?
check for the build sheet behind/under the seat springs or behind the gas tank. otherwise you should be able to tell if there was upper trim from looking inside the cab where the small piece of upper trim would have been between the door and bed. if it doesn't look repaired then it likely would not have had the center white. unless they painted interior too... can't see your first two pictures. someone with more knowledge of 72 two-tones might chime in. also, if the painter cut corners you might find evidence of original paint between the cab and bed, or under door seals, etc.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 10-29-2015, 10:13 AM   #3
Nitis
Nitis's Avatar
I've never seen a factory one with white down the middle that didn't have both upper and lower trim.
I personally think any restorations that don't involve trim especially if it was there originally is just cutting corners because it's so period correct. When I finally do my truck that had no trim on plan on adding the upper for sure.
Nitis is offline   Reply With Quote
Old 10-29-2015, 10:19 AM   #4
kentucky_smith
I haven''t been able to find a build sheet any where.
Old 10-29-2015, 11:20 AM   #5
68350
68350's Avatar
If it was a factory deluxe two tone(the center white stripe) it would have had upper trim. I'm betting the stripe was added. You should be able to find evidence of holes for upper trim if it had it
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-29-2015, 12:52 PM   #6
69Tom
69Tom's Avatar
Unless you wanted to add the upper trim, I'd personally go with solid green bottom with the white roof and keep the lower trim. Would look good, I think.
69Tom is offline   Reply With Quote
Old 10-29-2015, 01:18 PM   #7
joecaruso
joecaruso's Avatar
x2 I agree with that I would personally paint below the trim white and the cab white. I is a very good look especially where you only have lower trim.
joecaruso is offline   Reply With Quote
Old 10-29-2015, 04:35 PM   #8
71sierragrande
Petroleum User
71sierragrande's Avatar
That color is dark olive. Im sure it had the upper trim if its green/white/green originally.
Opinions are like you know what, but... Ive always felt that the upper trim hides/takes away from the curved upper body line too much, which is one of the beautiful things about this body style. So, I'd go solid green at least down to the lower trim, with no upper trim.
Nice truck
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 10-29-2015, 05:02 PM   #9
70sLover
Your paint job is so nice, I'd just add the top trim over the stripe and call it a day.
70sLover is offline   Reply With Quote
Old 10-30-2015, 12:43 AM   #10
OregonNed
OregonNed's Avatar
I do like that green! Nice truck.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-30-2015, 02:53 AM   #11
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Ah, so that's where it is.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-30-2015, 07:35 AM   #12
It's a Custom Deluxe, so may have never been deluxe two-tone. It could have had the deluxe two-tone option and when repainted the upper trim was not installed. I think I would go solid Dark Olive Poly. The trim stands out better when not two-tone
Old 10-30-2015, 09:40 AM   #13
bonehead
bonehead's Avatar
I love green trucks, I would do solid green with a white top.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 10-30-2015, 11:04 AM   #14
kentucky_smith
I need pics. Anyone have a 1972 Brochure?
Old 10-30-2015, 12:09 PM   #15
69Tom
69Tom's Avatar
Here's one.
Old 10-30-2015, 12:10 PM   #16
69Tom
69Tom's Avatar
And another...., but it has upper trim too. But you get the gist of the color. Sharp looking truck.
Old 10-30-2015, 12:12 PM   #17
69Tom
69Tom's Avatar
Here's a K20. No upper trim.
Old 10-30-2015, 02:17 PM   #18
kentucky_smith
Thanks Tom. Think I'll keep the white and buy the trim, even though I don't think it's right for the Custom Deluxe package.
Old 10-30-2015, 03:49 PM   #19
kingstrider
kingstrider's Avatar
Funny this is the first time I've ever seen an ALE-81 bottle on this site. My truck has the KY Historic tags too though I'm currently out of state.
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline   Reply With Quote
Old 10-30-2015, 06:31 PM   #20
Benny-
Great looking truck! Glad to see another Kentuckian on here.
Benny- is offline   Reply With Quote
Old 10-30-2015, 07:46 PM   #21
NTIMID8R
NTIMID8R's Avatar
Not two tone and not the original green be here is my solid colored dark olive with upper and lower trim. It came from the factory white/med. olive/white/med. olive
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 10-30-2015, 08:23 PM   #22
Mapearso
Originally Posted by 70slover View Post
your paint job is so nice, i'd just add the top trim over the stripe and call it a day. :d
+1
Mapearso is offline   Reply With Quote
Old 10-30-2015, 08:48 PM   #23
picklito
Wow. That's nice.
I like the green trucks. Especially the medium olive.
picklito is offline   Reply With Quote
