10-29-2015, 09:09 PM | #1 |
how do i know what size rotors i have?
So, I'm planning on ordering new drop spindles. Aside from measuring, how can i know what size rotor i have? It's a 1977 C10 Custom Deluxe
11-03-2015, 05:53 PM | #2 |
Re: how do i know what size rotors i have?
no option for heavy duty brakes, vin says Base: 1315. any help?
11-03-2015, 06:09 PM | #3 |
Honestly, measuring is the only way to be sure.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
11-03-2015, 06:17 PM | #4 |
11-03-2015, 09:57 PM | #5 |
I just ordered drop spindles for mine. I pulled a front wheel off and measured the rotor with my calipers. they were like .987'' so I am guessing they started at 1'' then wore down a bit with regular wear. I ordered stuff for 1'' rotors so hopefully everything works.
11-03-2015, 10:28 PM | #6 |
Most early trucks were 1 1/4 so that would be my guess but you could have either. Its always best to measure to be sure. Even if it came from the factory with one size a previous owner may have changed them at some point. Best to be sure before ordering parts. It saves you time and frustration.
Born and proudly residing in a Red State ! |
11-03-2015, 11:38 PM | #7 | |
On my truck I have 1.25" front and 11"x2" rear |
11-04-2015, 10:28 AM | #8 |
That's sort of my point. You have light duty rear brakes but 1 1/4 front rotors. I personally have never seen 1" rotors on anything older than 1977. That's why I said he could have either but checking is the best thing to do.
11-04-2015, 11:10 AM | #9 |
The 1" rotors are only used on the manual brake system and the lightest power system, so without even seeing your truck I would guess 1.25".
I have the brake system release chart for '74 scanned (I also have the '77 system in the book but not scanned) but it does not give a specific measurement. I also have the '87 system scanned, which is a bit easier to read. You can see how the rotors are released here, based on GVW and brake system RPO (JB1 vs JB3 vs JB5). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-04-2015 at 03:45 PM. |
11-04-2015, 11:13 AM | #10 |
yeller
If you are going to go thru the effort of installing drop spindles, you can easily twist off 5 lug nuts and measure the rotor thickness. Now isn't the time to be lazy, especially when it can cost you $$
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
