Editted by Staff
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by chevy_mike; 10-30-2015 at 11:15 AM. |
It's Better With Nitro
Re: Upper Rad Support/Bracket Mount Wanted
In my case, it was much easier to fabricate one myself and get it to fit exactly they way I wanted it - I went with a little taller radiators. The steel saddles and rubber inserts in different widths are available from most GM restoration vendors. I had some spare sheet steel and bent it accordingly, and then spot welded the saddles in place.
wow i just put my hands on one today and was wondering what To do with it..?(60)
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
![]() Join Date: Jan 2011
This thread will go away soon. You need to look at the rules on asking for parts for sale. You need to be a supporting member. If you just ask folks what they used that would be OK.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
