Old 10-29-2015, 10:30 PM   #1
TexasLS1
TexasLS1's Avatar
Installing Grease Fittings?
So this is a kindergarten-level question, but it's my first time replacing steering parts and therefore putting the new grease zerks on joints/tie rods. None of them are tightening very easily for me- in fact they're not even threading in. Am I supposed to be tapping threads before installing the fittings, or just forcing them in? I just hate the thought of screwing up new Moog parts that I just painted...
TexasLS1 is offline   Reply With Quote
Old 10-29-2015, 10:53 PM   #2
andrewmp6
Re: Installing Grease Fittings?
Look up in the hole you should see threats on them.
andrewmp6 is offline   Reply With Quote
Old 10-29-2015, 10:56 PM   #3
TexasLS1
TexasLS1's Avatar
That's what I was afraid of - I don't see threads in any tie rods or ball joints. The only part with threads cut is the idler arm.
Old 10-29-2015, 11:00 PM   #4
TexasLS1
TexasLS1's Avatar
I'll have to get some taps at work tomorrow, it wont be to hard to tap them. Just gotta keep the shavings out. Thought it was weird that almost all of the Moog parts wouldn't have been tapped already. Thanks for your input!
Old 10-29-2015, 11:07 PM   #5
andrewmp6
I haven't seen them not have threads in them but i haven't installed any in a while.
Old 10-30-2015, 09:29 AM   #6
SCOTI
SCOTI's Avatar
They should be threaded.
I just went through all the parts installed on my square-body CC dually (all Moog brand). Upper/lower BJ's, inner/outer tie-rod ends, a-arm bushings, & steering link parts all took the Zerk fittings. Some went right in. Others took more effort but still went in. None required tapping.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-30-2015, 11:27 AM   #7
TexasLS1
TexasLS1's Avatar
Ok, I'm probably just being a sissy. I just didn't want to strip any out or break a fitting by forcing it. Thought it was weird, though, that not a single fitting would start in any of the holes (other than the idler which was threaded). Thanks for chiming in guys.
Old 10-30-2015, 03:18 PM   #8
donandal
I just recently bought some moog ball joints.
one was properly threaded for the grease fitting, the other was
not.
took it back and next one was OK,.... properly threaded , so maybe
a bad batch?
donandal is offline   Reply With Quote
Old 10-30-2015, 05:24 PM   #9
oldman3
oldman3's Avatar
Lately all the fitting I've been buying are the type 6 self tapping, maybe that's what they sent you. Tried to load a file but can't get it to load...Jim
oldman3 is offline   Reply With Quote
Old 10-30-2015, 05:55 PM   #10
69gmcc10
69gmcc10's Avatar
I did the tie-rod ends on my 03 silverado last fall and none of the joints had threads for the zerks to go into. I just assumed they were self tapping because the zerks had a tapered threads and I screwed them in.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 11-01-2015, 02:09 AM   #11
BigMike
BigMike's Avatar
I just redid my front end a few months ago with all Moog parts and none were threaded. I assumed they were self threaded and just pushed down on them to get them started and tightened away. I got a little over zealous on one and broke it off, but I had other fittings and just put in a new one.
BigMike is offline   Reply With Quote
Old 11-01-2015, 10:23 AM   #12
TexasLS1
TexasLS1's Avatar
I was really worried about breaking them. I forced one (I'm surprised it didn't break!), but got a tap and tapped all the other holes. Now I've got them all painted and and reassembled to start putting the front end back together - just gotta finish painting my control arms. Can't wait for the first drive with the drop and all new parts
Old 11-01-2015, 11:02 AM   #13
andrewmp6
We want pictures when your done.
