Old 10-30-2015, 04:50 AM   #1
MacQuigley
Fuel Tank Options
My 62 Stepside came with a really crappy underbed fuel tank sort of fitted.
My original plan was to replace this with an original in cab tank and I think that's still my preferred option as I really don't want to drill a new bed for an under bed filler, but I have a question.
How much space will I lose in the cab if I return it to an original tank? Also as I think about it, are fuel fumes an issue with an in cab tank?
MacQuigley is offline   Reply With Quote
Old 10-30-2015, 06:26 AM   #2
dragon65
Re: Fuel Tank Options
I just went through the same thought process and decided to move it to the rear. I have read about the fumes being an issue in a lot of cases here. You do gain storage room and a clean look if you keep it out of the cab and I believe the safety issue is real important to consider. I just insulated my entire cab and will be rugging over the rear section where the tank was.
dragon65 is offline   Reply With Quote
Old 10-30-2015, 06:44 AM   #3
PGSigns
PGSigns's Avatar
I have moved mine out the cab on both my trucks. In the old days I did not mind having it in the cab but now I don't like the smell at times and really don't like the safety aspect of it. The fuels we have now are all formulated for sealed tanks and evaperative control systems. They have lots of additives in them that make the new gas stink. For me the further away the better. There are some other advantages to keeping you tank on the back. It does help the weight split on the truck and that helps the handling.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-30-2015, 06:54 AM   #4
MacQuigley
s there a bed tank available for a Stepside that doesn't have the filler come up through the wood?
Old 10-30-2015, 06:58 AM   #5
dragon65
sure is.....they have side vent tanks. A lot of guys here have the fender-panel side conversion filler door installed---behind the license plate drop down and in the bed stake, also even in the fender well. A ton of choices and the tanks can be gotten for under $200
Old 10-30-2015, 07:08 AM   #6
MacQuigley
Would I have to modify a top/side will tank to do that or is there a kit available?
Sorry to ask so many dumb questions but these trucks and American vehicles in general are new to me and Im still finding suppliers for parts.
Old 10-30-2015, 07:30 AM   #7
dragon65
they sell tanks that have the side fill ready to go. You just need to get the extra specified parts to go from the fill tube to wherever you are routing it. I mounted mine and got the fuel line and the fill pieces and cap for under $250 all in
Old 10-30-2015, 07:34 AM   #8
dragon65
I see that your in Scotland.....I assume you have part catalogs from a few American suppliers right.
I was born in Barry Island Wales.....live in the states now for 50 yrs
Old 10-30-2015, 07:55 AM   #9
MacQuigley
Already met a load of ex pat's .
I've been working my way through various websites like LMC and Classic Parts. Its a steep learning curve.
Old 10-30-2015, 07:58 AM   #10
dragon65
It sure is a challenge...one step at a time. It took me 3 years and Im still working on it. How did you acquire your truck? I am sure few and far between in Scotland
Old 10-30-2015, 08:06 AM   #11
ol_skool_chevy
ol_skool_chevy's Avatar
1965 mustang tank...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-30-2015, 09:57 AM   #12
Paul Y
That looks like a nice installation.
I am in the same boat of looking for a 'cost effective' rear mount tank with the added complication of needing in tank pump for my LS conversion. Would love a Tanks or No Limit unit but the near $800 price tag means it is a no go along with the shipping.
Fuel is a different formula in the UK, I only get smell in the cab if I fill the tank to the top, but think this is more to do with an old sender and seal than anything else.
Agree on the safety issue, mind you I think I would be more worried about the steering spear...I mean shaft....
Look forward to hearing more options especially the $200 dollar tank mentioned above. Do you have details?
P.
Paul Y is offline   Reply With Quote
Old 10-30-2015, 10:30 AM   #13
Mackie
Mackie's Avatar
You lose some storage space but not leg room. The seat won't go back any farther.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 10-30-2015, 11:06 AM   #14
Chevy Fleetside
Chevy Fleetside's Avatar
I went through Tanks inc and put this tank in one of my trucks. http://www.tanksinc.com/index.cfm/pa...rod/prd173.htm . I did have to shave the frame a tiny bit on the sides but not a lot. I also used 3/4 pipe on top to drop it down a bit as this tank doesn't hang real low. This will allow me to put on a 90º spout so I can put the fill out side the bed. Right now I am filling through the bed. The down side is it is only 16 gal. You can also get an in tank fuel pump if you want one. I don't have any pictures of the top but can take some when it is empty.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-30-2015, 12:16 PM   #15
MacQuigley
Im desperate to order some parts because of the time it will take to get them here but I need to make the right decision which ever way I go so a bit more research is required.
Thanks for all the ideas so far guy's. Feel free to keep them coming.
As for where I got my truck, there is a chap in Grangemouth that regularly ships in American cars and trucks, even the odd bus. But there still isn't a lot of choice.
Old 10-30-2015, 09:15 PM   #16
ol_skool_chevy
P.
the mustang tank was under $100.00 on ebay
Mark with Chalk
Cut with a torch
Old 10-31-2015, 01:24 AM   #17
Captainfab
60-66 Nut
The Mustang tank will not fit the '60-'62 frame as it does a '63-'72 frame. Plus a Ford sending unit will not work with a GM gauge let alone accept an in tank fuel pump without extensive work..
Most of the rear gas tanks mentioned are designed to or just happen to fit the '63-'72 frames nicely. The '60-'62 frames are wider and consequently will require some extra work to fit a different tank. I believe Dave Boyd makes a fuel tank specifically for the '60-'62's which can also be fitted with an in tank pump. But it is not going to be cheap.
http://www.boydwelding.com/
Boyd welding is a forum vendor and can be found in the Vendor Marketplace.
The tank shown by Chevy Fleetside is a nice universal tank that would fit your need also.
Old 10-31-2015, 12:09 PM   #18
'63GENIII
'63GENIII's Avatar
Hey Captain, any idea how much wider the 60-62 frame rails are at the insides? I had to trim the lower rails on the '63 to get the Blazer tank in. IIRC almost 3/4" off of each side. If he were to run the Blazer style tank, he may not have to do any trimming? It could also be set up for the in tank pump and rewired for the right sending unit.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-31-2015, 12:22 PM   #19
ol_skool_chevy
Sorry......they make a Universal sending unit that fits the Mustang tanks now to work in GM cars and trucks....
Mark with Chalk
Cut with a torch
Old 10-31-2015, 02:07 PM   #20
Sik5chevy
Would you throw up a link for the universal sending unit please sir..
chris
Sik5chevy is offline   Reply With Quote
Old 11-02-2015, 01:51 AM   #21
Captainfab
60-66 Nut
I don't remember exactly, but off the top of my head it is 6-8". With that vintage of Blazer tank the width isn't the issue, but the length, front to back will likely be an issue on a shortbed. However it is a good choice for using an OEM in tank fuel pump. The one drawback is the sending unit will be 0-90 ohms which won't work with an original gas gauge.
Another option for a fuel tank would be the '48-'53? Chevy car tank, that Lakeroadster used under his truck. Those have a side fill tube and a 0-30 ohm sender
Old 11-02-2015, 01:56 AM   #22
Captainfab
60-66 Nut
My apologies, I have not heard of such a thing. I was not aware of a 0-30 ohm sending unit for a Mustang fuel tank. Would you care to post a link to where to find one?
Old 11-02-2015, 02:09 AM   #23
Chevy Fleetside
Looks like Tanks inc has a mustang universal gas tank that you can use one of their universal sending units. Unlike regular mustangs this tank has the sender on the top of the tank and not on the front side. http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm
Old 11-02-2015, 02:52 PM   #24
Brad54
Brad54's Avatar
How much space is there between the top of the frame rail and the bed of the truck? Wondering how much clearance there is for the fill neck out of the side-fill tank in GENIII's post.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-02-2015, 02:56 PM   #25
DakotaKid
POL Advertizes an aluminum tank for 60-62. 21 Gallons. right around 400$ I believe.
didn't think that was too bad.
https://www.performanceonline.com/19...as-Tank-19809/
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
