Old 10-30-2015, 02:53 PM   #1
michael bustamante
michael bustamante's Avatar
how to on drop blocks
i got my 67 short stepper on new POL 4" coil drop springs in the rear with new ECE shock relocators and kyb`s.
I have a feeling im going to need to go 2" lower. rather than swap springs and most likely have 2 different brands i was thinking of doing two inch drop blocks. So how do these install in a coil spring suspension and whered be a good place to buy some ?
1967custom
michael bustamante is offline   Reply With Quote
Old 10-30-2015, 03:03 PM   #2
WarMonger
WarMonger's Avatar
Re: how to on drop blocks
They go on top of trailing arms and under the rear end. I usually just make them. Not sure where you can buy them?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-03-2015, 02:11 PM   #3
michael bustamante
anybody got any pics? warmonger makes sense but i wanna see the drop
1967custom
Old 11-03-2015, 02:50 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Contact member way2lo2. He sells them on here.
Keith
Convert to disc brakes.
Old 11-03-2015, 02:52 PM   #5
lolife99
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Keith
Old 11-03-2015, 03:02 PM   #6
michael bustamante
thanks guy i really appreciate it!
1967custom
Old 11-04-2015, 01:24 PM   #7
19SIKtySix
19SIKtySix's Avatar
Also, another place to check that carries lowering block kits is AVS suspension, they offer them for a great price, I'm looking at getting a set also.
Hope this helps.
-Chuck
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 11-04-2015, 05:52 PM   #8
n33k0
Hope this helps.
-Chuck
AVS offers a lowering block kit starting at $35.00, but not for all of our trucks apparently. When I emailed AVS about the 1" block kit they said it wouldn't work for my 1972 C10 (coil spring rear) and that I would need a specific set that would work with the trailing arms which would cost $89.95.
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 11-04-2015, 06:23 PM   #9
hugger6933
The $20 and $30 dollar "kit" don't have the U-bolts with them and are for leaf rear and just have the locating pin not the u-bolt holes like the one should have for the coil trucks. Jim
hugger6933 is offline   Reply With Quote
Old 11-04-2015, 09:32 PM   #10
fast&low
EBay or CPP (classic performance products )
fast&low is offline   Reply With Quote
Old 11-05-2015, 02:36 AM   #11
Sklptrljay
Sklptrljay's Avatar
I went to a spring shop with a stock u-bolt and had them make some longer ones.
.......Cost $30.
Then I got some heavy gauge rectangular steel tubing and drilled out 2 hole's for the u-bolts.
.......Cost $5
Perfect ride height....priceless.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 11-05-2015, 06:52 AM   #12
clos69
Its Topless Season!!!!
clos69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
Here is a quick DIY...easy to do.
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 11-05-2015, 08:30 AM   #13
midniteblues
midniteblues's Avatar
I dont know what size rim/tires your running.
but just be careful of your scrub line. If you get a flat you could be stuck on the road.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-05-2015, 10:43 AM   #14
n33k0
That might explain the price difference. The website picture for the "kit" shows two blocks, four U-bolts, and eight nuts. They didn't have a detailed description/information written about the kit, that's why I emailed them to ask before sending them my money. It seemed like a too-good-to-be-true at that price (and it was!)
Nick
Old 11-05-2015, 10:46 AM   #15
fast&low
Nick
Just visit CPP eBay store fast & easy
Old 11-05-2015, 10:48 AM   #16
n33k0
Originally Posted by fast&low View Post
Nick
Yeah, I've been shopping around for a while now comparing prices, not ready to pull the trigger on any parts until I have the time to do the work. I just wanted to post that info I got from the AVS customer service in case it could help anyone.
Nick
Old 11-05-2015, 11:06 AM   #17
fast&low
Ok it won't take that long if you have air tools I did each sides in around half an hour.
Clean the factory U-bolts with wire brush & spray with WD40 heavly especially where the U-bolt goes into the control arm there will be years of rust & mud in there you may also need a BFH.
Good luck
Old 11-05-2015, 12:00 PM   #18
EARNHARDT#3
EARNHARDT#3's Avatar
Never reuse the u-bolts. There are some things you can cheap out on but you really don't want to take a chance with u-bolts and have your axle come out while driving down the highway.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-05-2015, 12:04 PM   #19
michael bustamante
Originally Posted by clos69 View Post
cool man thanks for the dyi . i got a spring and suspension place right down the street from me
1967custom
Old 11-05-2015, 12:07 PM   #20
fast&low
Well for one thing I don't think you can reuse them because I don't think there long enough with the lowering blocks .
Cleaning them with the wire brush is only to make it easy to remove the nuts on the U-bolts.
Old 11-05-2015, 12:23 PM   #21
fast&low
Sorry EARNHARDT#3 now I see why you said that and yes I fully agree
Old 11-05-2015, 12:28 PM   #22
EARNHARDT#3
Yeah I've reused ones that are pretty new but even that is risky. As far as removal I just cut them with my angle grinder with a cutoff wheel. Makes quick work of them.
Old 11-05-2015, 12:39 PM   #23
fast&low
Yeah you can cut them off and I thought about that but I was glad I didn't on the driver side it was stuck in there pretty bad so I had to beat on the threaded side of the bolts to get it to pop out. (A lot of rust & dirt)
Don't know about using square tubing square tubing is prone to rust on the inside as well as the outside so I don't know how long it will hold up .
Seems it would only be a cave for mud and water?
Old 11-05-2015, 11:05 PM   #24
Sklptrljay
Sklptrljay's Avatar
I primed and painted the tubing first. Mine won't ever see dirt or mud.
